C6 headlight lens
C6 headlight lens
Can the lens on the C6s be sanded,buffed and polished then add a coat of clear coat without further damage? My vette is a 08 77000 miles..Thanks for any help..
They can, but the material is very very hard. A pneumatic sander with 320 grit just dances around on it. Having done sets myself, its seriously worth the cost of new or reproduction ones.
Cherokee Nation (11-10-2017)
Go Fast:My are not turning orange.The coating GM put on them is starting to peel and and looks like crap,I can peel small pieces off with my fingernails.I use 400 grit wet & dry with a small block and sanded one left corner and it took the coating off,so i quit there until i decide if i should get the 3M kit or Mothers kit and use my drill and try on one lens?.....I know of the DIY of replacing them with new lens,but that is a PITA. I'm an old fart (74),but i can work a drill and i do have the buffing and polishing products.
I didn't say anything about them turning orange?
The 3M kit or Mother's kit are not up to the task of repairing these headlights. You are welcome to attempt it, but its a huge can of worms and a very difficult headlight to get right. Not to mention many many hours of work.
I had a headlight doctor guy come to my house and polish one of my lenses. Not sure if previous owner had replaced the driver's side due to a collision or if the lens got bad over time and was replaced, anyways the drivers side is 10 out of 10. My passenger side was probably a 6 out of 10 and was getting worse. A friend told me about the mobile service so I had the guy come out.
They sanded down the lens, used some sort of abrasive to polish, then buffed it out with a final clear coat. I would now put the lens at a 9 and maybe 9.5 out of 10... you have to look really close to notice any difference between the two. The charge was $75.00, it took them about 30 minutes. Also came with a 5 year warranty.
Not trying to downplay the 3M or any other lens product but I would highly recommend getting the pros to do the work for you especially given the relatively low cost and the warranty offered.
Yes, they have been since 2000. I agree that is a heck of a warranty... although i did look in the small print there is a $25.00 chemical charge after 1 year. Even if I have to get it re-done, way cheaper than a new headlight component or the lens replacement hassle.
