Suggestion to remove these faint white marks?
The handle is a hard plastic so i don't know if there's any solution to that one but all along the panel are some faint white lines (hard to see, i know) that i'd just like to eliminate. I've only tried some maguires interior detail which only solves the problem for a couple seconds until it dries..
https://imgur.com/a/XOoHv
Just looking for suggestions on better products that might work.
Former Vendor
You can use our LC on door panels, dash & seats,
http://adamspolishes.com/shop/interi...r-cleaner.html
http://adamspolishes.com/shop/interi...nditioner.html
oAllElseFailo (03-02-2018)
Cant really make them out but if they are whiteish splotchy things then I think its from body sweat . I think its combined with the gassing process that is prevalent with these cars. I would clean the door good with mild soap and water then use a product and layer it and see what happens. Your never going to stop sweating so a build up is neccessary. Hows the other door?
Clif
Clif
Clif
Clif
Clif
