Quick Q on application pads
Will be applying about 4 coats of Z2 later this month and once applied, I will finish the top coat with a few, maybe 2 coats with Z-CS. Anyway, what pad will be best to use to apply the Z2 with from Autogeek? I will be using my portal cable buffer.
I never got the best results with Zaino Z2 or Z5 with orbital application. I only got great results with hand application, Zaino applicators but tried a foam applicator pad, in the specification Zaino recommended. If I was to be real honest, orbital application always seemed to leave a "residue" that showed up with dust in the orbital pattern. Anyway, it still looked great, just not as good, IMO, as the hand applied.
GRZLDVT1 is a forum member who has a detail shop and they apply the Z-CS followed by Z-8 3 times and he says it's the best look he has achieved.
Just a thought and good luck.
thanks, I have done both, by hand and buffer, I really never seen a great deal of a difference. Since this will be going on my garage queen, and, I will be taking my time, maybe 2 -3 days to complete, I will apply by hand. It is easy to do just as well, and better control as to a full application and surface coverage. I do plan to apply about 3 maybe 4 top coat of Z-CS, followed by Z-8 wipe down in between each coat of Z-CS. I do, also plan on cleaning the surface, with clay bar, followed by Z-AIO.
