Flat/semi painted plastic under the hatch c6z?
Anyone find a product that would just make this look nice, even, not glossy but just dress it up a bit? Thanks.
It's painted flat/semi gloss plastic so far as I can tell. Some under the hood too.
If you are talking plastic only pcs that aren't painted, I know Meguiars makes a water base detailer that you mix to your desired sheen, there may be others available as well. Griots has an interior detailer that is low gloss.
froggy47 (11-01-2018)
I just wipe mine down with Meguiar's X-Press spray wax sprayed on a microfiber towel, or you can use Meguiar's Hyper Dressing diluted with distilled water, diluted to the sheen you like.
froggy47 (11-02-2018)
Bump.....more discussion needed......as my underside hatchcover "black" is soiled from trying to clean
with the wrong product...
Needs cleaning and sealing with ????
303, Pledge ?????
303, Pledge ?????
The paint used on the rear hatch is the worst stuff I have ever seen. It cannot be spot painted, cannot be cleaned with anything stronger than Dawn and water. If you try to use anything with a thinner base like alcohol, Goo Gone, some paint thinners, lacquer thinner or such the black will come off, never try any of these. I have used 303, Megs Back to Black, various waxes, nothing works very well. Megs Back to black used with a DA polisher seems to work the best for me, still not great. I have seen the hatch stripped and painted car color or black which would be the best if you want to spent the time and money. I hate this part of the car.
Best so far for me is 303 but that's on top of others, may strip with dawn & reapply.
Aside from repetitive application requires to maintain a decent appearance, I stay away from water/solvent base products due to out gassing residual film deposit and visible on interior glass, which requires frequent cleaning. That maintenance process proven to be an unending task!
Few years(5?) ago, I used Gtechniq C4 on hatch, but 4 months ago, since I was re-doing my ceramic exterior coating, I stripped and use Kamakazi ISM on hatch as well as all plastic/rubber interior/exterior trim.
IMO, no better semi permanent and relative maintenance free product for use to encapsulate exterior/interior plastic/rubber trim. Damp MF wipe down is all I very seldom need on coated interior surface.
Ceramic coating has relieved me from once a time consuming process of making a car look good.
Received 1,043 Likes
2019 C6 of Year Finalist (performance mods)
I used some of Adams aerosol In and Out spray. Just use a light even coat. Looks great. If you get to heavy with the spray it will run so use a couple of light coats.
Pro Mechanic
Received 3,952 Likes
IF I still had a coupe, I would have applied ceramic coating to keep it looking great.
got2hav1 (12-15-2018)
