Foam cannons
Foam cannons
Normally hand wash my car.I have a 3000 psi pressure washer. Does using a foam cannon with washer still require a hand rubdown even for slightly dirty vehicles? If so I can’t see the advantage. What foam gun off amazon and soap do you guys rec.If the job ommitts hand rub with good results I could see how it’s a lot faster and easier.
Bikeman (11-14-2018)
Foam guns and cannon's are used in conjunction with shampoo's designed to foam and dwell. These are used on moderately to heavily soiled vehicles. Before putting cloth/sponge/mitt to paint you want to remove as much dirt/grime as possible. The guns/ and cannon in tandem with the foaming shampoo and left to dwell lifts a lot of the filth away. Rinse and wash after that. Lightly soiled cars do not really need to be foamed. In those cases a good pre-soak ( I like to perform a 2 step pre-soak) will loosen up or rinse away the larger or built up dirt.
Bikeman (11-15-2018)
