Meguiars Hybrid Ceramic Wax - My Review
I saw a lot of coverage and hype around this product, and figured i would give it a shot. I'm not someome who thinks these thousand dollar coatings are worth it, but i'm also someone with 4 vehicles in the fleet, 3 of which live outside and 2 of which are daily drivers. Theyre also an SUV and a truck, and going extreme on care for them isnt in the schedule. Theyre lucky to get any care. So i figured i would give this stuff a try, and overall i'm pleased, especially for the price.
The spray bottle is of decent quality, doesnt feel like it will break before i use it up. Minor pet peeve, the bottle itself is blue, and not see through, so you can't see how much product you have left. It has a overall pleasant smell, a mix of blueberry and chemical. Better than most meguiards dmells IMO, but not as nice smelling as stuff from Surf City Garage or others.
Real talk, you will screw up the initial application. They make a point of spraying it on heavy and rubbing it in. How tos on youtube and others will show you this method. If you do that, it will dry to a splotchy mess. What they don't sjow you is that after it driea, you have to come back with a damp towel and buff it off. Maybe there'snsome kagical in between amount to use between "full coverage" and "too much", but i didnt find it either time. I did find it really easy to fix with a damp rag though. Anyways, it goes on easy, and application is super easy and fast. It doesnt have a cure time either, spray it on and you're good to go. I went side by side and had no issues with it drying too quick or anything like that. It doesnt stain trim and you can get it on glass without issues (they dont recommend using it on windshields because it could streak, but say a thin layer wont hurt).
Performance wise, the stuff looks great, one of the most reflective spray waxes i've ever seen. It beads and rejects water, but if you don't use fancy water sprayers to make it look great, it just runs the water off. Frankly, i'm fine with that, i don't get my kicks from pictures of water beads on my daily. I can't speak to durability yet, but it seems like it lasts 6 to 9 months if you domt do anything speal to rejuvenate it. Nice thing is you can add layers of the stuff, all yoou do is spray it on while the car is wet, rinse the car off, then dry. I suspect that with that ability, if you can wash the var once a quarter you will always have awesome protection.
Overall, i'm very pleased with it. I think it is probably rendering these high dollar coatings obsolete. They may last longer, but if all i have to do is spray the car down real quick after washing to rebuild it... who cares? And at 12 to 15 bucks a bottle, it represents a HUGE value.
Gixxerman (09-25-2019)
Received 1,401 Likes
I tried it this weekend on my SUV, thought it worked really well and went on easy. I didn't have the splotchy mess, just misted the whole car after I washed it, sprayed, wipe it around, then back over with a dry towel.
Smells pretty good too.
I'm curious to see how it holds up.
What about using on top of wax or sealant ? I'm guessing since it does not have a cure time, it does not need to bond to the paint. Sounds interesting and worth a try. Thanks for the review.
Would be pretty redundant to use over them but it should be fine to overlay
Received 1,033 Likes
St. Jude Donor '09-'10
Not likely. There is far more to products than shiny and easy to use. While I haven't personally given this product a try, the recent rash of ceramic-infused 'this-and-thats' simply don't have enough time on them yet to make a true judgement. Yes, you can simply apply more at each wash (as you can with products like Gyeon WetCoat and CarPro Hydro2) but eventually the buildup *may* cause issues of clarity and overall performance.
The ridiculous claims of coating 'hardness' and scratch resistance aside (mostly because it's all a load of marketing mumbo-jumbo that has very little, if any, impact or validity) coatings offer far more than just looks. One of the primary reasons I like coatings is that, well...I'm lazy. And they allow me to be lazier while still maintaining protection and reasonably good appearance. One of *my* major benefits of coatings is durability and resistance to environmental contamination like water spots and bird bombs. Don’t wanna have to worry about running home and immediately dealing with removing things that would otherwise etch bare paint. Like hard water spots did to our Corvette during the Zaino years. Also has to last cuz I don’t wanna be hauling out compounds and polishes every Spring, given reasonable maintenance.
I also value exceptional Self Cleaning Abilities: Our cars see rain and often get rained on in the morning and then sit outside in the sun in the afternoon; don’t like waterspots. I like clean cars but don’t like cleaning cars.
I'm an admitted coating junkie, mostly for reasons that benefit and appeal to me personally. I don't suggest that my wants and needs are universal or the best way to do something. Given the inherent subjectivity in appearance, maintenance and cost issues, everyone is different and should follow their own path.
This is in no way an indictment of the Megs HCW Wax product; Megs is a solid company and I'm sure that this product will likely work as advertised, aside from longevity claims (if they indeed make any) as there are *far* too many factors to go by what may be written on a product label.
However, I will stand by my initial thought that in no way will this product render expensive coatings obsolete; separate product classes, separate expectations, separate results....and obviously separate costs.
It is nice to see that ceramics, in whatever form they take, are making it to retail shelves in an easy to use format. I always thought Gyeon CanCoat would be a killer retail products given its ease of use, relative low cost and proven performance.
FYRARMS (03-12-2019)
I agree. I have been following most of the new "SiO2-infused" products that have become available over the past year or so. I have a friend who swears by Jax Wax "Ceramic Wax" liquid SiO2-infused sealant. I know he then uses a topper/spray SiO2 sealant after washes to extend the performance. Neat stuff. However, based on a few of the YouTube detailers I follow, I will be passing on such products. The longevity/performance just isn't significantly better than a good synthetic spray sealant to me. Both the Meg's HCW and Mother's CMX lasted longer than P&S Bead Maker and Nanoskin "Nano Shock", but not enough to justify the cost for me. I suppose if I was going to use a cheap spray product as my only means of paint protection, then I would use something like the Meg's HCW. I only use sprays as toppers, however.
Meguiars doeant make any crazy claims on it. They say nothing about scratch resistance or anything. They don't say anything other than "better than conventional wax" for durability.
I know a lot of pro detailing people are being really harsh against it. To me that says they're scared of it impacting their business.
For me, this product needs to be good at self cleaning. The cars got rained on yesterday and still look great, like they were just washed. Obviously that's after only a single day, but it's certainly better than if I had used a conventional wax.
I'm interested to see how it holds up over the long term.
With the recent glut of 'spray coatings' I find it curious how many claim to be "revolutionary", "first of its kind", "truly unique", etc., etc, etc. when, in fact, Gyeon has been doing it longer (and so far better) for the past few years with CanCoat. Easy to use, great candy gloss and self cleaning, 6 months longevity without breaking a sweat. Until someone topples CanCoat from it's throne, the rest are mere pretenders...which is not to say the others are bad products with no place on the shelf as that is completely untrue. Most products have their place in a variety of situation and it's just a shame that some mfg can't accept the 'slot' their product falls into without trying to elevate it to something sensational, not thru performance, but thru marketing.
And kudos to Megs for not mentioning hardness and scratch resistance as that is such and over-hyped and over-marketed aspect of coatings, an aspect I don't even consider when looking for a new coating to try. Even the vaunted claims of "Diamond-infused 10h hardness" means little as, at the end of the day, my fingernail will still leave a heck of a mark on it. Adam's and their "9h Ceramic Spray Coating" could learn a bit from Megs approach regarding that claim.
All that matters at the end of the day is if using the product meets your expectations; does it make you smile when you turn around and look at your car as you walk away from it in a parking lot? If so, then what anybody else thinks is pretty much irrelevant. "Find something you like and use it often" as the saying goes.
Just tried this on my car and truck and the bottles pretty much done. :/
Turned out really good on the car but left a blotchy mess on the truck so Ill have to take the op's advice on wiping it down again with a damp cloth.
Heres a follow up to this. I've had it on 2 cars for a bit over 6 mo.ths now. Last night I reapplied it to my girlfriends black SUV. It was still heading, but it had lost some of its gloss. The car sits outside, has seen a good bit of commuting and road trips, and the front was covered in dead bugs from a trip last week.
So overall, I would say 6 months is pretty great lifespan for a black car outside 24/7. My silver truck appears to be holding up a bit better (but that may be just due to the color). I did a more normal application this time, spritzed a little onto the wet car, and then wiped the car dry. It came out looking pretty great, as good as day 1 and went a lot easier.
Overall, I'm sold on this stuff. I think it's the best daily driver product I've ever used.
FYRARMS (09-24-2019)
Its still beading very well on my Cayenne too, not much change in gloss but the car is silver so its hard to tell anyway.
Just be careful all with the whole "beading -it's still protecting" Not an indication of what is more important -UV protection.
Good point! I am slowwwwwly going through my detail sprays and spray waxes (I have a lot to use. LOL) and using my Optimum Polymer Technologies products more frequently. I like that everything they offer includes the same cross-linking polymers with UV protection. Everything jives. Their paint cleaner, waterless wash, detail spray, and carnauba spray wax all leave some really good protection behind. And everything is so damned affordable.
In the real world we would all prefer sheeting action over beading any day. it's just not sexy ( who doesn't love all those tight beads- and with a good coating( think Syncro,at least in the first 2 months) that rush of beads when you move is great theater).But beading can leave to spot's.
OPT used to love them and still do. Them and CarPro are 2 main staples with some great products out there. It's just too much fun to try others
Brian at Apex has a new YouTube video out, and he tests a TAC Systems spray wax that added a LOT of gloss. Like, the surface went up 5 full GUs on his gloss meter. The entire video I am thinking "I need to buy some", and then his closing statement was "folks, don't be like me and horde products".
yamabob (09-24-2019)
Moderator
Received 3,748 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
lol I saw that vid on shinee wax from tac systems looked pretty wild stuff FYRARMS. I personally have guys thinking my car is ceramic coated, but it's not. Just going thru your steps and using a topcoat like Beadmaker can yield excellent results.I would hate ceramic on my Corvette.. it would take one of things I love and that's detailing my car.. I really love detailing.. a pride and relaxation thing for me. I actually use a few meguiar's pro products.. still a good company. liked your review up there...For you engine bay when detailing it I spray it down with Meguiars Hyper Dressing.. diluted with distilled water 1:1 too sticky I ended up thinning it out with more water more like 5:1 as I like the satin clean look and not shiny hooker lip look in my engine bay lol
Gyeon hits the right spot for me. Annually, a quick polish with Gyeon Q2 Primer, then CanCoat the next day. Sometimes the daily drivers get grimy and don't get washed for months in Northeast Ohio, but when they do it's with Bathe+ and after drying I'm always pleasantly surprised at how good the paint looks.
yamabob (09-25-2019)
