Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Bead Maker for Windows
Old Oct 1, 2019 | 04:08 PM
joemessman's Avatar
joemessman
Default Bead Maker for Windows
I was amazed to find out this is the best stuff I have ever used for cleaning windows inside and out. I was pretty leery at first to try it but did it on one of my other cars fearing that it was going to smear rather than clean. But no. I couldn't believe how easy and quick it was to use on my Vette windows inside and out.
I have used Sprayway for years, as that was the best I had ever used. But Bead Maker just blows it away.
Old Oct 1, 2019 | 08:51 PM
FYRARMS's Avatar
FYRARMS
Bead Maker does a great job, smells good, and helps keep the inside of the windows from fogging easily. Most quick detail sprays work well too. It really is the type of towel and your method that makes the most difference.
Old Oct 1, 2019 | 09:39 PM
SixAddict's Avatar
SixAddict
Not only Bead Maker but Adams waterless wash and their pink detail spray. Like Fyrarms says it's all in the towel and method, found this out through trial and error.
Old Oct 1, 2019 | 10:32 PM
FYRARMS's Avatar
FYRARMS
Two of the best-smelling products in their lineup!
Old Oct 2, 2019 | 02:02 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I find with Beadmaker a heavier "plush" Microfiber works best
Old Oct 2, 2019 | 11:01 AM
FYRARMS's Avatar
FYRARMS
Speaking of plush, I have become totally addicted to the new TRC Eagle Edgeless 600 towels. Not just the 600gsm weight, but the softness. I always use a two-towel method when applying spray products. A short-nap low-weight towel for spreading stuff out, and a plush towel for buffing. I already have a bunch of the great Eagle 500s, but the 600s are just nicer. I highly recommend trying a couple the next time The Rag Company or Autogeek has a sale. I want to make pillow cases out of these things.
Old Oct 2, 2019 | 11:59 AM
joemessman's Avatar
joemessman
I like these. Especially on the rear fascia they pucker right into all the nooks and creases.
Old Oct 5, 2019 | 03:54 PM
Drklingler's Avatar
Drklingler
Ok I’ll ask, what is the optimal towel and method for best results?
I’ve just been using Windex wipes which work ok but could use some improvement.
Also any recommendations for the window exterior? Something to help get the bugs and gunk off easier?
Old Oct 5, 2019 | 04:11 PM
FYRARMS's Avatar
FYRARMS
Skip the wipes, as they just kind of smear. The key to clear windows is the "dry wipe". Use two towels. A very short-pile cloth for applying glass cleaner and wiping the glass clean (look up "waffle weave glass towels"), then, dry buff the windows clear with a second microfiber towel. The type of glass cleaner you use isn't very important.
For bug splatter on windshields, I just pre-soak them with a blast of glass cleaner in most cases. Let them soak a bit before wiping the glass.
Old Oct 7, 2019 | 07:43 AM
Edmund Iverson's Avatar
Edmund Iverson
These are the two "rags" I use for the windows of my, and my clients', glass-
https://www.theragcompany.com/diamond-microfiber-glass-and-window-towel/
https://www.theragcompany.com/the-pr...rofiber-towel/
A two-towel method keeps things from streaking. Like FYRARMS said, use the short nap and get it "damp" with the cleaner by the way, for applying, long nap for buffing. And Beadmaker is an excellent choice for that last topper! Optimum OPti Seal is great, too, but not as glossy
To Bead Maker for Windows
