Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Removing Ceramic Coating
Old Nov 18, 2019 | 09:40 AM
CSixDude's Avatar
CSixDude
Default Removing Ceramic Coating
I'm in the process of prepping the car for Avalon King's ceramic coating, and I'm just wondering, how hard is it to remove this stuff if I later want to take it off? Anyone on here ever remove ceramic coating from a car?
Also, I'm curious if it will shift the color of the car any. Thoughts?
Old Nov 18, 2019 | 10:19 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
You would be the first I heard of using it, would like to know how it goes
Old Nov 18, 2019 | 10:20 AM
vader86's Avatar
vader86
On any panels I messed up, a LC white pad and finishing polish was enough to remove the ceramic from the panel. Came off fairly easily with the DA, but it wouldn't budge by hand.
Old Nov 18, 2019 | 12:16 PM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Can't say for sure as I've never used that one but most coatings will be easily removed during the prep/correction process. A medium polish on a light cutting pad will get rid of a majority of coatings out there, some a light polish on a polishing pad. Some of the more tenacious ones will require compound and heavier cutting pad. There are a *very* few pro coatings that require wet-sanding, Gtechnic Crystal Serum Ultra being one of them I believe.
You may notice a slight darkening of the paint when applying the coating, some darken, some don't; removing will return to original paint shading.
In 2016 our 2004 Vette started the season with one coating, I removed and re-coated mid-summer with another coating, then removed that and re-coated with yet another coating in Fall.
You don't really need a specific 'coating removal polishing step', just happens naturally as part of the correction process.
Old Nov 18, 2019 | 12:28 PM
FYRARMS's Avatar
FYRARMS
Holy hell! Wait a second... Does that mean you could do spot-corrections with mild polish to remove minor surface swirls on a panel without stripping and re-coating it? If so, that is really cool, and that would be my ceramic coating of choice.
Old Nov 18, 2019 | 05:44 PM
BudgetPlan1
I doubt it...the minor surface swirls would be either 1) In the coating layer or 2) in the clearcoat beneath the coating layer. Either way, the coating would need to be cut through/leveled which would require wet sanding to breach/level...that's gonna leave a mark!
Having no experience with that product, can't say definately but I guess it would be interesting to see. I do know that the application notes for CSU mention being VERY careful during application as once cured, if a high spot is found its gonna take more than a compound and aggressive pad to remove.
Again, it's all conjecture on my part so I dunno for sure.
Old Nov 19, 2019 | 12:04 AM
Grzldvt1's Avatar
Grzldvt1
I might be a bit more experienced than most on this subject. While I am not familiar with Avalon King, it looks like all the others so using a compound like Jescars Cutting Compound or Adam's Paint Correction Polish with a Rupes Yellow Pad(s) Have removed several different Ceramics and corrected many other detailers high spots
Old Nov 19, 2019 | 06:30 PM
CSixDude's Avatar
CSixDude
Finished the application of the Avalon King Shield IX after claying, polishing, and then buffing the car. The prep was a lot of work, but the finished product looks good. We'll see how it hold up over time. Had a lot of the product left after I was done, so now I'm wondering if there is any benefit in putting on another coat.
For what its worth, Avalon King got some good reviews on several sites that claimed to be independent.
https://www.carbibles.com/best-ceram...ting-for-cars/
https://www.bestnetreview.com/best-c...ting-for-cars/
To Removing Ceramic Coating
