Beadmaker question
Exactly...it's not Zaino! You can't just keep layering until you trade in your Corvette.
If you were looking for additional protection and gloss and didn't want to ceramic coat the car...if you wanted to stay in the polymer world...
This is arguably the "best" solution I could think of:
https://www.esotericcarcare.com/poli...aster-sealant/
I'd use that product without question, if I wanted polymer goodness and maintain with Beadmaker
I've never been too big a proponent of the whole drying aid concept. While I don't generally disagree with its primary concept, or if it actually works, I always preferred forced air to dry the car. That being said, I've used different products (BM included) as drying aids from time to time in various wash situations.
And while our illustrious resident Jedi Master detailing guru @FYRARMS states above "it doesn't work well on top of all coatings", I'd be willing to respectfully suggest that perhaps it may not have been the coatings that were the issue. Please allow me to explain and share my experiences with it and the experiences of many here in South Florida.
- My experience is that BM is finicky to start with and many have a tendency to drench the panels with it because, well... "more is more better".
- Weather also plays a crucial role in BM's level of "friendliness" when it comes to application. Here in the hot sticky humid south east, BM works better when you spay most of what you are going to use in a section directly into an MF cloth and then the remainder directly on the panel. In other words, take 70% of the amount you want to use in an area, and spritz the MF towel, then hit that section of the panel with the remaining 30%.
- I've found that towels play a crucial role in BM application - I'd use a short nap 360-420 gsm 70/30 towel like an edgeless 365 as the application towel and move to a plush circular knit weave 500 gsm towel like an Eagle edgeless 500. The Twist loop fibers of many drying towels work well to dry the car, but in my experience, do little to buff in drying aids such as a drenching application of BM. I always had to go over the section with the plush towel (eagle 500 or similar) to buff anything out and get all the gloss I was looking for. And that is what I suspect might be happening to you.
And like our resident Jedi Master Fyrarms states, I too no longer use it on my coated car since it is a step back in performance as compared to an SiO2 product, if all you want is insane gloss and slickness and are not concerned with water behavior and durability, it is a compelling product to use. But let me say this...once my BM supply runs out, I am moving over to what I call "the SiO2 version of BM" I am going to purchase Xtreme solutions Topper. I've had lengthy conversations with some guys doing shoot outs and all the results are congruent - Topper is the new BM type of product but a V2.0 in that it's chemistry profile is SiO2 and not polymer. The gloss and slickness are off the charts like BM but the water behavior and durability is a lot more inline with what you would come to expect from an SiO2 product.
I hope this helps, so maybe you give BM another chance with some different towels along side your main drying towel? Let me know if I can help you further.
Best to you and stay healthy,
Loki6
Its probably well know on the many detailing forums & sub forums that I am no fan of BM- Now I usually dont post in threads related to BM anymore cause it just gets those who are BM fanatics upset, but every now and then I just cant help myself to chime in on my SEVERE dislike of BM & how much of a worthless product I know it to be from experience
The PAHG product I recommended in my post you quoted, Master Sealant, is a bit more intricate to apply (but not much) Should you want a spray on wipe off product, I’d strongly recommend PA High Gloss or PA Cosmic Spritz
Also to note, master sealant in not an SiO2 product it is a polymer. If you want the SiO2 version of Master Sealant, Cosmic Glasscoat V2.0 is the one you want. PAHG and PACS are also SiO2 products infused with TiO2 and either would be the perfect selection to maintain Cosmic Glasscoat, or use alone on your naked clear
I might have to try the cosmic glasscoat. Looking for something new to replace the crystal seal for a final topper/maintenance layer.
Edit - I probably should mention the vette is covered in llumar PPF. Are people using the glasscoat over it?
