Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Simple question
Old Aug 30, 2022 | 08:40 AM
OldC8Guy's Avatar
OldC8Guy
Default Simple question
I bought a new car (not a Vette) and want to put a ceramic coating on it. A simple question for the experts and non-perts out there, do I have/need to clay bar the car if I plan to polish it before coating?
Tanks in advance
Old Aug 30, 2022 | 08:47 AM
rpiechowski's Avatar
rpiechowski
Wash, Use Iron remover, wash again, Clay bar, paint correct polish, surface prep for ceramic, ceramic coat per directions. Let it cure...
Old Aug 30, 2022 | 08:52 AM
yamabob's Avatar
yamabob
Yes. The best practice and especially for when coating is a clean, prepped surface. 95% of your shine comes from polished paint. That last little bit is the LSP or last step protection( some can dial back the shine some too).
Since these ceramics are a longer term proposition, you should decontaminate with an iron remover, wash, clay,polish, and in the minimum an IPA wipe down or panel prep product before coating. This not insures your finish is up to snuff, but allows for the best bonding to the surface of the coating.
You can clay bar or use the mitt. Now go get busy and we expect pics
Old Aug 30, 2022 | 03:48 PM
vader86's Avatar
vader86
My C7 got coated with 500 miles on it, which a lot of was the drive back from Bowling Green.
The clay did remove alot more than I expected.
Old Aug 30, 2022 | 04:24 PM
rpiechowski
Who are you calling stupid Vader........???
Old Aug 30, 2022 | 04:27 PM
yamabob's Avatar
yamabob
Nay, he’s just promoting his group again
Old Aug 31, 2022 | 05:00 PM
OldC8Guy's Avatar
OldC8Guy
In the category, Bend Me Over and Have At Me, the Eagle One Black Plasti Coat Wheel Cleaner that performs as well as the professional iron removers is advertised all over the place at $6.99. Amazon has it at a deal making $19.99!
Old Aug 31, 2022 | 06:07 PM
yamabob's Avatar
yamabob
It works. Not quite as strong as Iron X but 2 times and its all good. It really depends on what you see
Old Sep 1, 2022 | 03:48 PM
endus's Avatar
endus
The answer is to use clay if you need to use clay. If you wash and then run your fingers over the paint and it feels bumpy, or if you can see little spots of tar or whatever, you probably need to clay. If if feels smooth, you probably don't.
It's not unlike polish. Do I need to use a very aggressive polish before I ceramic coat the car or can I just use a lighter finishing polish? Well, if the paint is in bad shape you need a more aggressive polish. If the paint is in good shape you don't need a more agressive polish. Clay is just another step in removing contaminates from the paint. It doesn't do anything magical.
I am usually hesitant to clay, mainly because I am lazy and have a bad back, but also because you can mar the finish and cause yourself more work when you go to polish. Polishing will get rid of the smaller contaminates on paint the same way clay will. If there are larger contaminates or I'm afraid its going to dirty up my pads too much, then I'll clay.
Old Sep 1, 2022 | 05:12 PM
yamabob's Avatar
yamabob
Well that is actually incorrect. While claying can induce micromarring, it is not any worse than bad wash induced swirls and rids. Polish in any event,
Clay is to remove imbedded contamination while polishing removes surface contamination. the proper way to see if it has any is to place your hand in a baggie and run the back side of hand over paint. Any grabbiness is contamination.
You can do whatever you want on your car. However advice os to properly and prep the paint surface as best as possible before a coating application.
Old Sep 1, 2022 | 10:43 PM
macguyver's Avatar
macguyver
If your gonna polish, I would clay first. Liquid fallout removers ( IE: ironX and the like ) are a way to remove ferrous contaminants while claying is the mechanical means to remove not only what the chemicals get but also impeded contaminants that the liquids dont. Can you get away with not claying and just polish?-- probably ,but claying takes so little time anymore and its really worth it. do the baggie test like yamabob suggests-- it works.
Also
If your gonna ceramic coat any vehxcle brand ne or not-- you BETTER polish it first.
Old Sep 2, 2022 | 08:48 PM
NextOne's Avatar
NextOne
Tanks in advance
I bought a new white car about 15 years ago. The car looked like "new" as it should the evening I took delivery. But after getting home and inspecting it in the sun I could see and feel little bits/specs of grit in the paint.
I clayed the car and got lots of surface contaminants off. Some new cars are shipped by rail, and rail yards are full of ferrous dust that settle right into the paint of those new cars in transit. In my case, clay left the the car slick as glass. Also made the subsequent polishing far easier.
Old Sep 6, 2022 | 03:53 PM
endus's Avatar
endus
Agree that it's no worse than the swirls introduced by doing a bad wash, but I don't do bad washes for the exact same reason!
My goal is the minimum amount of work for a swirl free finish. If the contamination is small enough that it's not visible it will come off during the polishing step with no extra work required and no additional damage to the paint. If the contamination is visible then I will probably use some clay.
Old Sep 6, 2022 | 04:02 PM
yamabob's Avatar
yamabob
Again, not really correct. There are in-bedded contaminants are may be above the surface and below. Polish and pad “ glide “ over these and do not remove all. They can also cause damage while buffing. Its’an easy extra step that will produce the best results. When coating the idea is the best cleanest surface you can achieve. Wash, decon chemically and mechanically, polish, ipa wipe at minimum ( a panel prep is beftter ) Coat. these ar the proper steps to take. Again- you can do whatever you like, i didnt help pay for your car . i am giving the correct steps to be taken
Old Sep 6, 2022 | 05:03 PM
endus's Avatar
endus
23 years of polishing almost exclusively without claying first and I have never caused a single swirl with either a rotary or RO by doing so. Foam pads are extremely forgiving.
Clay all the time if you've got the energy and a good back. It won't hurt anything, it may even help. I have neither, so I will continue to save labor by avoiding unnecessary detailing steps when I can.
Whether anyone thinks I am "correct" or not is not really something I concern myself with after a couple decades of doing something a certain way that consistently works.
Old Sep 6, 2022 | 05:19 PM
yamabob's Avatar
yamabob
Hey if it works for you amigo . My point is telling the OP the proper steps to take. I only started getting paid to detail in ‘78. So i too have some experience. All good.
I dont clay every single time either. Unless and especially if it’s a new customer. Repeats I would baggie first.
Old Sep 6, 2022 | 06:42 PM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
I agree with Post 15. At 80 years old the back appreciates not over doing anything. If you find easier means to get the shine go for it !
To Simple question
