Do any of you gurus have actual numbers for the thickness of the following layers: paint, clearcoat, polish (aka Zaino), Carnuba wax?
Everyone says "the clearcoat is thin", but I'm interested in knowing exactly just how thick (or thin) these layers are. Is a coat of Zaino 1/1000 as thick as the clearcoat or 1/2 as thick (or 10 times as thick!)?
Wether a Vette or a Buick, the various layers are pretty much the same.
You can see the layers, and how they are applied, mil readings, etc in the Tech Tips Section at http://www.autoint.com
The amount of Zanio, Mothers, Mequiar's, etc that are applied and adhere to the paint are not measurable without some very, very expensive lab equipment.
Even a $1,000 electronic paint thickness gauge can not measure the amount of wax/sealant on a vehicle. You can also see one of these gauges in use on the site.
