Recently, someone mentioned that they intended to use their leaf blower to dry the car after washing. I too tried that but found the leaf blower a little ungainly and a bit heavy to manage close to my car. But I discovered a small Ryobi blower that is easy to handle and I already had the battery pack. I have nothing to do with them or any retailer, just passing along an idea. It is a very handy and relatively inexpensive solution.
I bought this one since I have five batteries that I use with my eight other One+ Ryobi tools. It's real easy to handle but it uses up the battery pretty fast. A 2 amp hour battery is just enough to do the car.
I used to do a quick sweep with 175psi air from my 80 gallon 240v 7.5hp compressor with a wide air nozzle then towel dry anything left. Great for cleaning the wheels after foaming them up too. Maybe a low pressure high CFM blower would work better but never tried. Anyone else use compressed air?
I've used the one above for years on all of my vehicles. Most of my vehicles are ceramic coated, and the blower takes off the majority of the water. My only complaint is that it's fairly loud, so when you're holding it up high (like to get the roof of a truck), and it's close to your head, it's quite loud...
Also, the entire black portion on the "shop" blower is rubber, so it more than likely won't scratch like my larger plastic chute ryobi blower that I use for the yard...
Killer! My old man has a similar setup... puts my little harbor freight junk to shame lol
I have an oversized 3 car garage and it's completely filled with every machine shop tool you can think of (One of my many hobbies). My 3-axis Bridgeport CNC milling machine is the main attraction.
I have a Ryobi also. It works good, gets heavy after a while.
If the battery dies or it is not doing the job, I just turn on the air compressor and finish with that.
Either one works, always take more time than I expect.
