Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
DIY ceramic? Difficult?
Old Jan 13, 2025 | 12:54 AM
scoutsakimbo's Avatar
scoutsakimbo
Banned Scam/Spammer
Default DIY ceramic? Difficult?
A place near me wants to charge $1500 to ceramic coat my car. I have a magnetic red c6. Is this difficult to do correctly or is it easy to ruin it?
Can I just go get some stuff myself and do a good job really easily? If recommended for diy what brand should I buy?
Old Jan 13, 2025 | 06:06 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
With some reasonable attention to detail, well within the abilities of a DIY-er.
A guide that gives a nice overview of the process: https://blog.esotericcarcare.com/gui...g-application/
Old Jan 13, 2025 | 10:48 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
I do my Sierra Denali and wife’s Nautilus with Mohs Ceramic and topped with Mohs Can Coat, do the prep and easy to coat your Vette easier then a truck for sure.
Old Jan 13, 2025 | 01:03 PM
vader86's Avatar
vader86
Its easy to do yourself, $1500 is not a terrible price though. I would ask what product they're using.
The work is in the paint correction step, not the application of the product. I just did my 4Runner and will be redoing the vette before I bring it out for spring with Kamikaze Miyabi and ISM coat. Miyabi is easy, the ISM needs more attention.
Old Jan 13, 2025 | 03:54 PM
Homer3D's Avatar
Homer3D
I don’t think applying ceramic coating itself if overly difficult, but it is all the prep work before that takes a lot of time. The washing, decontamination, polishing, paint correction, etc. If you already know how to do all that, applying the coating should not be hard for you. I currently have Ceramic Pro 9H on my corvette. https://ceramicpro.com/products/
Old Jan 13, 2025 | 04:34 PM
slowtealz28's Avatar
slowtealz28
It's all in the prep, and coatings can vary drastically from one to the next and can also vary depending on the conditions when you're applying (temperature and humidity). After getting quotes for my car, I invested some time learning how to do the process and eventually bought two different size polishers, pads, and everything else you can think of. The first coating I ever used was a pro coating which you're supposed to be certified to apply. It was very difficult to apply and I had a ton of high spots which I had to go back and fix. The car turned out amazing. I have since done multiple cars with different ceramics, most of which were much easier to install. I would practice on a beater car, or go to a body shop or junk yard and get a hood to practice on. Don't chase perfection if youre doing it yourself. And most corvette have extremely hard paint which requires more aggressive pads and/or compounds.
Old Jan 19, 2025 | 02:03 PM
cmonkey713's Avatar
cmonkey713
As others have said, "It is all in the surface prep". The surface that you apply the ceramic over must be scratch and swirl free. When the ceramic or PPF is applied you lock in any surface imperfections that may be present. Depending on the condition of your paint $1500. may not be too far out of line. Check on what high end detailers would charge just for the paint correction and use that as a base for the $1500.
Old Jan 23, 2025 | 10:05 PM
Bigredtruckguy's Avatar
Bigredtruckguy
I’ve done a few of my cars myself. It’s a lot wasier
of you have the tools. I did a bunch of research before I bought my products. Check out Scott HD on YouTube. He has tons of comparison videos and you can see the results.
Old Feb 2, 2025 | 02:42 PM
mdolandese's Avatar
mdolandese
Like said the prep is the key for success. Some products may be harder to work with than others. Most of them are novice friendly. You definitely could do it yourself. I highly recommend polishing before coating. The ceramic locks and protects everything in place so it’s critical you like your preb work before you ceramic coat it. The preb and the polishing makes it look like mirrors and glass Not The Coating!! Preb/polishing=gloss,shine and perfection Coating= protection durability
Old Feb 4, 2025 | 10:12 PM
JLSuperfly's Avatar
JLSuperfly
Can you ceramic after wax?
Old Feb 4, 2025 | 10:20 PM
Bigredtruckguy
I would not put it on over wax. You can do it the other way though.
Old Feb 5, 2025 | 10:25 AM
vader86's Avatar
vader86
Won't stick to each other, so no.
Can work the other way around but it needs to be a wax made for ceramics. Kamikaze has one.
Old Feb 5, 2025 | 02:10 PM
Homer3D's Avatar
Homer3D
No, You want paint free of any oils or residue. One of the steps for 'surface prep' is to use an IPA solution after you have done all your polishing/paint corrections and right before applying ceramic coating. If you apply wax first, then that wax will be a layer on top of your paint and will not allow the ceramic coating to bond to the actual paint surface.
And while you can wax AFTER the ceramic coating (once it is completely cured), there is no point in this. It is best to just use a ceramic based car shampoo and follow that up with a ceramic booster spray. I literally clean my ceramic coated cars once a year now.
Old Feb 6, 2025 | 02:36 PM
John Ulrich's Avatar
John Ulrich
I get 16+ vehicles out of a can of Gyeon Can Coat for $50ish on sale.
To DIY ceramic? Difficult?
