Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Ceramic coating
Old May 22, 2025 | 10:23 AM
RHarkey1's Avatar
RHarkey1
2nd Gear
Default Ceramic coating
I recently purchased a Vette from a gentleman in Florida. He always used carnauba wax but I'm interested in changing to ceramic coating. Any recommendations on the process? Should I get a professional ceramic coating first or is the process simple enough for me (I'm not very experienced in detailing vehicles)? TIA
Old May 22, 2025 | 10:26 AM
vader86's Avatar
vader86
Plenty of advice in the Car Care Section here, Esoteric and Autogeek have YT videos on the process.
I did it myself with Kamikaze Miyabi + ISM coat. You just need to do a paint correction with a DA and compound so that the coating is applied directly to paint.
Old May 22, 2025 | 10:53 AM
Zjoe6's Avatar
Zjoe6
Moved to car care forum for better responses.
Old May 22, 2025 | 04:29 PM
cmonkey713's Avatar
cmonkey713
The paint must be completely free of any previous non-ceramic coatings. A good clay bar and paint correction should leave you with a good surface to apply the ceramic. If you don't feel confident in a DIY project at this level, would suggest having it professionally applied.
Old May 22, 2025 | 11:35 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Anyone can apply ceramic coating, it is the prep that takes the most time. I had my C5 professionally corrected and ceramic coated, well worth it!
Old May 23, 2025 | 11:15 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Here is how I did my wife’s Nautilus, I did a polish as this removed the dealer junk they use, then panel prep. I use Mohs followed up a day later with Can Coat, then every 6 months or so I top again with can coat. My C8 has 100% PPF and after 3 yrs I now just top with can coat every 3 or 4 months.
Old May 23, 2025 | 03:44 PM
slowtealz28's Avatar
slowtealz28
I would suggest DIY. Search Auction Car Reconditioning on youtube, and go back and watch his paint correction and ceramic coating videos. I spent around $1200 for all the tools, pads, polishes, and ceramic to do my first car. Now it costs me $200-$300 per car that I do. Most of the "real" ceramic coatings you can purchase are user friendly. I prefer to use the pro grade because they last longer, but you should still get 1-3 years out of a DIY ceramic if you take care of it properly. None of them are lasting 5-10 years.
Old May 24, 2025 | 09:23 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
A nice overview of the process: https://blog.esotericcarcare.com/gui...g-application/
Old May 27, 2025 | 04:43 PM
h422694's Avatar
h422694
wash it twice using Dawn diswashing soap to get all old wax of. Then follow vendors instructions, generally above wash, clay, alcohol wipe down, then ceramic. I've usedvAdams products for years and have not washed car in years. Just wipe down with cold water, blow dy with leaf blower, and pick up any remaining water drops with good micro towel. Have gotten 8 top 3 class finishes in 10 yrs.
Old May 29, 2025 | 12:16 PM
yamabob's Avatar
yamabob
Please do NOT listen to the above advice!!!
Old May 29, 2025 | 01:29 PM
yamabob's Avatar
yamabob
Curios as to what “pro grade “ coating you use. Who are you certified with?
Old Jun 10, 2025 | 11:35 PM
slowtealz28
Armour detail supply quartz pro. And I’ve done artdeshine/apex’s old metal oxide coating
Old Jun 11, 2025 | 08:18 AM
yamabob's Avatar
yamabob
Fair enough. A pro-sumer coating. Enjoy amigo
Old Jun 11, 2025 | 04:40 PM
slowtealz28
whatever you wanna call it, I just know with all the prep you put in before doing the coating, most of the consumer ones really aren't worth it. I havent done the ADS quartz pro yet, but the metal oxide coating was an absolute beast.
Old Jun 12, 2025 | 05:27 PM
yamabob's Avatar
yamabob
That’s cool.I’m finding longevity here from any product reduced a lot. High UV and high humidity, they fail sooner and set up is a little more of a bitch. I don’t find the prep bad- maybe because it calms me down
Old Jun 13, 2025 | 04:15 PM
slowtealz28
I'm sure the weather is similar to here. hot and muggy. Products will flash almost instantly unless you put them on in a temp controlled garage. We have all kinds of exotic plants and trees and if any of them get on your hood or roof they will destroy most coatings on the market. None of the coatings I've used hold up to the back end of cars that are not running cats, I don't there there's anything out there that could.
To Ceramic coating
