Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Zaino - first time user
Old Jun 18, 2003 | 01:16 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Zaino - first time user
Just ordered some Zaino. Does the Dawn dish soap do a decent job of removing old wax? How many coats should I do right out of the gate?
Old Jun 18, 2003 | 01:27 PM
Bodhi's Avatar
Bodhi
Default Re: Zaino - first time user (LT-4 CE)
Dawn does a great job. The Zaino website has great directions. If you are using the ZFX additive (I highly recommend you do) you can do a maximum of 3 coats in a 24 hour period.
I would recommend you clay bar the car before you begin the Zaino treatment. Zaino sells a clay bar but there are many others out there also. Break off a chunk of the clay and mash it into a circle about the size of a silver dollar...uses a spray bottle with water and a little car wash in it to lubricate the clay bar. The clay bar is awesome for getting anything off your paint...
Old Jun 18, 2003 | 02:27 PM
RubyRedTX's Avatar
RubyRedTX
Default Re: Zaino - first time user (Bodhi)
Actually, I wouldn't use water and would recommend the Z-6 spray in conjunction with the clay bar. I didn't feel the need to clay my entire car. I did use it on the sides, at the very bottom under the doors to remove some road tar. As said, follow the Tips and Tricks section on the Zaino website.
Old Jun 18, 2003 | 07:44 PM
vette_dreamer's Avatar
vette_dreamer
use dawn once is enough.
Old Jun 18, 2003 | 08:30 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
moving to "Car Care"
Old Jun 18, 2003 | 09:29 PM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: Zaino - first time user (Mr Mojo)
You only Dawn before the first coat and then never again. As for initial coats, 1 if you are using Z1 first, up to 3 if you are using ZFX. Also, apply a light coat of Z6 between coats.
To Zaino - first time user
