Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
HELP....HELP....BEEN SKUNKED
Old Aug 2, 2003 | 05:21 AM
blk05coupe's Avatar
blk05coupe
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Default HELP....HELP....BEEN SKUNKED
on the way to work this morning about 4:00am i hit this little skunk :banghead: :banghead: now i can't get within 10 feet of
the car. it stinks inside out out :banghead: :banghead: how and the
hell do you get this smell out.....
Old Aug 2, 2003 | 12:40 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Default Re: HELP....HELP....BEEN SKUNKED (my01zo6)
I've heard tomato juice is good for it ;)..... Check under the car and try power spraying any area that might have come in contact with the little fella (maybe a run through a car wash will be needed) and for the interior try Fabrize a spray deodorizer.
Good Luck. :chevy
Old Aug 2, 2003 | 05:03 PM
Killrwheels's Avatar
Killrwheels
Default Re: HELP....HELP....BEEN SKUNKED (gq82)
One of those do-it-youself spray washers is probably a good place to start. Probably some meat in the air-intake under the car. I cannot imagine the smell .....
Old Aug 2, 2003 | 10:37 PM
96CollectorLT4's Avatar
96CollectorLT4
Sounds like you got guts on the underside of your car. ( actually broke the perfume sac ) Must get pressure washer and clean under car. Car wash, or getit up on some ramps. Did the same with my truck one time, it stunk to high heaven, got under truck and found parts of guts hanging off running board brackets. Washed off and it was fine, spray some orange power on it if you want.
To HELP....HELP....BEEN SKUNKED
