Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
buffer/polisher help
Old Feb 7, 2004 | 06:05 PM
Oyishdog's Avatar
Oyishdog
Default buffer/polisher help
I have always detailed my car by hand, however, it becomes a real pain after a while. I don't know much about using orbital buffers etc. I have a few questions:
1) What kind of buffer/polisher to buy?
2) What type of pads to use/buy?
3) What is the process using a buffer? i.e. application? removal? etc?
4) anything else I should know/ask?
This is may be a simple question and an annoying post for some of you car care buffs, but I really don't know :) Any advice? Thanks!
Old Feb 7, 2004 | 07:10 PM
DsC5's Avatar
DsC5
Default Re: buffer/polisher help (Oyishdog)
Forgot to preface this by saying I really don't see a need to use a buffer unless you are doing swirl removal, etc. One exception is to use a gray pad and Meguiars #7 Show Car Glaze - see below.
I would buy the Porter Cable 7424 buffer here:
http://www.coastaltool.com/cgi-bin/S...eff+1076249042
It includes the velcro backing plate and 6in counterweight.
Then a few gray, white and yellow pads from:
http://www.properautocare.com/porcabac.html
For products, I recommend:
3M Swirl Mark Remover (for dark cars in your case)
http://www.autogeek.net/3mperswirmar.html
Meguiars #83 Dual Action Cleaner Polish
http://www.autogeek.net/megdualaccle.html
Also, while not an abrasive polish, if you're not using Zaino, Meguiars #7 Show Car Glaze works very well using the Porter Cable and a gray pad. Top with Souveran or similar and it works great. Using #7 by hand really sucks.
The 3M SMR works very well for very minor swirling/scratching - i.e. towel scratching. Anything more than very minor marring, or water spots, you're better off trying Meguiars DACP.
Typically I use the 3M with a white pad and the surface is back to perfect again. Sometimes you need a bit more and can try it with the yellow pad. Any more serious problems call for DACP with the yellow pad. I like to follow up with the 3M and white pad after DACP - sometimes DACP can leave a little hazing or visible marring in the finish.
As for the actual application, with 3M SMR, I leave the PC on 4 and work it in with light pressure. You can watch it break down from a gray polish to a clear oily liquid. Once that happens, I wipe it off using:
http://www.autogeek.net/cobdettowinb.html
These towels are really great.
For DACP, I start with the PC at 3.5 or 4, and work up to 5 or so as it breaks down. Sometimes it takes a while. The break-down process is similar to SMR, but takes a bit more work. I then follow up with the SMR to clear up any hazing, etc.
If you're using a carnauba wax, you're ready to go straight to it.
Also, if you get any streaking or smearing while trying to remove the 3M or Meguiars, I like to use Meguiars Final Inspection.
http://www.autogeek.net/meg34finin.html
If you're using Zaino, get a spray bottle filled with 50/50 isopropyl alcohol and distilled water, and wipe the car down using one of those towels.
Here's the results after 3M SMR and some Zaino:
[Modified by DsC5, 7:17 PM 2/7/2004]
Old Feb 7, 2004 | 07:59 PM
CHARGED UP's Avatar
CHARGED UP
St. Jude Donor '13-'14-'15-'16
Default Re: buffer/polisher help (DsC5)
:crazy: Just a question is this an IVY League thing. :nopity
Old Feb 8, 2004 | 08:59 PM
DsC5's Avatar
DsC5
Default Re: buffer/polisher help (CHARGED UP)
:skep:
I'd be more concerned with the details my signature below. :p: :steering:
Old Feb 8, 2004 | 09:05 PM
Oyishdog's Avatar
Oyishdog
You two should race for pink slips :thumbs: Time for a s/c for the Z :jester
Old Feb 9, 2004 | 10:45 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Quote: buffer/polisher help
~One mans opinion / observation~
PC Accessories
PC Usage
Definitive PC Thread
Detailer's Dream: Porter Cable Random Orbital Buffer
~Hope this helps~
Experience unshared; is knowledge wasted…/
justadumbarchitect * so i question everything*
Old Feb 9, 2004 | 10:56 AM
TOGWT's Avatar
TOGWT
Default Re: buffer/polisher help (TOGWT)
It seems that you can't re-name hyperlinks on this forum, so I've added the full version...
PC Accessories http://www.autopia.org/forums/showth...threadid=14421
PC Usage http://bimmer.roadfly.org/bmw/forums...1430487&page=1
Definitive PC Thread http://www.autopia.org/forums/showth...threadid=14421
Detailer's Dream: Porter Cable Random Orbital Buffer http://www.roadfly.org/magazine/7/po..._buffer.1.html
~Hope this helps~
Old Feb 10, 2004 | 06:45 AM
Killrwheels's Avatar
Killrwheels
Porter Cable 7424 :yesnod: :yesnod: http://www.coastaltool.com or http://www.autogeek.net (couponcode corvetteforum saves another 10% off)
To buffer/polisher help
