Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
bug removal?
Old Mar 15, 2004 | 01:48 PM
snampro's Avatar
snampro
Default bug removal?
in the past I have removed bugs and tar with a bug and tar removal spray, what techniques do you guys suggest?
Old Mar 15, 2004 | 02:35 PM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: bug removal? (snampro)
Stoner's Tarminator works good. If they aren't that big I will use a small piece of clay bar and a lot of lube. After I use the piece of clay I throw it out. Regardless, the most important thing is to remove them quickly. The longer they stay on the suface the more damage they can do, especially the killer bugs in the southeast.
[Modified by Silver2002, 2:35 PM 3/15/2004]
Old Mar 15, 2004 | 05:42 PM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
If you have a good waxed finish they should come off pretty easy. :cheers: :seeya
Old Mar 16, 2004 | 12:08 PM
snampro's Avatar
snampro
yeah, well I don't have the car waxed yet. I've only had it for 4 days and the first two were driving. Now I have some bugs...
What about bug & tar remover? I have a good one from Turtle Wax I use on my other cars...
I'm sure it will be easier when I get it waxed...
Old Mar 16, 2004 | 12:42 PM
Silver2002's Avatar
Silver2002
I would get as much off with wash and water as possible and then use the bug & tar remover only on the spots that have remaining bug residue and scrub with a seperate twel or applicator. After that I would apply some wax/polish as I have seen some removers(havn't had experience with the Turtle Wax) that strip wax off as well. Check out this article if you are still unsure: http://www.bettercarcare.com/articles.php?articleId=7
To bug removal?
