Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Drying using a leaf blower
Old Apr 7, 2004 | 08:48 PM
SizzleChest's Avatar
SizzleChest
Default Drying using a leaf blower
is it the best/easiest method? I don't have a blower and i'm thinking of getting a cheaper electrical model. i've tried the drying by driving method and that doesn't work at all. Seems that a leaf blower would have the same effect... :confused:
Old Apr 7, 2004 | 09:16 PM
JohnnyB's Avatar
JohnnyB
Default Re: Drying using a leaf blower (SizzleChest)
If your car has no polish on it (like my daily driver) the leaf blower doesn't do much, but when I use it on my Corvette, the results are amazing. It is the only way I dry it now.
Make sure you get an electric one, the gas ones leave a thin film on the paint :cheers:
Old Apr 7, 2004 | 09:30 PM
DetailingDude's Avatar
DetailingDude
From: Chit!! Somebody keyed my Karma and now I'm pissed
Drying your car with a leaf blower is pretty good. You can get a wet/dry vac that triples as a blower. Just be careful around the emblems as you can get dirt from beind them that you can grind into your paint.
Here's a video that I did that show's how you can How To Dry Your Corvette With Water
Should make it quite fast next time.
Old Apr 8, 2004 | 03:15 PM
6SpeedBowtie's Avatar
6SpeedBowtie
St. Jude Donor '08-'09
Default Re: Drying using a leaf blower (DetailingDude)
I am sold on the "drying with water" technique that DetailingDude has mentioned. I saw it on his site and decided to give it a try. The first time I did it, I noticed that I still had a few little water beads on the car that I had to dab off with a chamois.
After adding a coat of Zaino, I washed the car again, and when I "dried with water," 98% of the water was off my car. A great method to dry the car.
Old Apr 8, 2004 | 08:37 PM
chevysales's Avatar
chevysales
i use the toro 215mph electric leaf blower with no attachment...would never go back to anything else. my car is covered in zaino and it makes it easier with a coat of polish or wax on there.
i would shy away from using a shop vac in place of leaf blower wether or not it sucks crap thru the tank is debatable but it is blowing thru a hose that sucks junk up thru.
just my opinion.
btw the toro's can be had at home depot for $55 and i have a niced paved area i wash on which i hose down first so i can use it with no fear of blowing anything up when doing lower sides. no matter what these cars really drip water out of areas for days it seems :(
the less times one touches the paint the better.
[Modified by chevysales, 8:39 PM 4/8/2004]
Old Apr 8, 2004 | 09:04 PM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Default Re: Drying using a leaf blower (chevysales)
If you go the electric leaf blower way make sure the model works without the tube attachment. It will make hafling a lot better. Also be sure to keep it away from the car's surface so that you do not accidently scratch it.
Old Apr 8, 2004 | 10:31 PM
red04coupe's Avatar
red04coupe
After reading posts on this forum recommending use of a leaf blower, I bought an electric Toro and tried it for the first time yesterday. I was totally pleased with the results. I ended up using both hands, holding the nozzle end in my left hand to make sure I didn't accidentally bang it into the car.
Old Apr 8, 2004 | 10:36 PM
hcvone's Avatar
hcvone
Default Re: Drying using a leaf blower (red04coupe)
Good choice, it will save you a lot of time in drying, the leaf blower gets the water out of the mouldings and mirrors, and you will be washing and drying less towels. :)
To Drying using a leaf blower
