Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Engine Cleaning?
Old Apr 17, 2004 | 02:14 PM
jerrythomas911's Avatar
jerrythomas911
3rd Gear
Default Engine Cleaning?
Would like to know how others clean their engines. A little afraid to just take it to the car wash and spray with the hose. Is this simply how most do it? Is it ok to do that? Suggestion much appreciated
Old Apr 17, 2004 | 02:22 PM
2PHA5T's Avatar
2PHA5T
Default Re: Engine Cleaning? (jerrythomas911)
hmmmm well i usally put my vaccum cleaner into it and suck up all the sand it has in it from me going to the beach. :cheers: but besides that i really don't know beside just amoral for the plastics inside. Washing it with water would scare me. :shocked:
Old Apr 18, 2004 | 12:36 AM
Wayne88's Avatar
Wayne88
For starters:
Degreasor & a hose.
Keep water away from the distributer, opti spark & generator.
Go slow & learn as you go.
You will be doing it many times-now & in the future.
I detail the engine as a pastime.
Old Apr 18, 2004 | 06:19 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I do it all dry and by hand.
I use a fine brush to get out large stuff, then Eagle 1 on Al parts and Formula 2001 on vinyl & rubber, buffing off any excess.
For greasy areas I've been known to use some brake cleaner on a rag before polishing.
Old Apr 20, 2004 | 10:58 PM
KnightRider02's Avatar
KnightRider02
Default Re: Engine Cleaning? (2PHA5T)
I just cleaned my engine today as a matter of fact. I did the vacuuming part in all the crevices. I took off the hood liner and gave it a vacuuming as well. While it was off I wiped down the inner hood with a damp microtowel. Shined it with some mothers protectant after. My engine wasnt bad. Most of the dirt came off with just hose water. Cover your battery and wires when your wetting the engine. To clean mine i used Griots Garage Engine Cleaner Kit. It comes with 4 brushes, engine cleaner, and engine gloss. I worked in small areas apraying the cleaner and agitating with a soft brush. After the entire engine was done I started the car and dried it. Let the car run for about 10-15...this will aid in the drying. Once it was dry I sprayed the engine gloss on the black parts, hoses, and colored wires. I am telling you that the engine compartment looked factory fresh and I am not exaggerating. Some parts I used a wipe to shine up, but mostly I used the gloss. It was worth the money for the kit. You can go to griotsgarage.com to purchase and view their other products. Try it and you wont be dissappointed!!!! :chevy
To Engine Cleaning?
