c5 engine cleaning
I'm a bit worried about affecting the electronics too.
Some club members spray their engines at the quarter car wash and have had no trouble. Knowing my luck, I'll drown something and be in trouble.
:crazy:
Nevermind the dirt on top of the power steering reservoir...I just noticed that....off to clean!
[Modified by doo600, 4:21 PM 4/28/2004]
Now, I'm a bit of a neat freak about my engine bays as you can see here on my GTP:
Thats the engine with 37k miles on it. Now, in that car, I used to follow this procedure
1) park the car with a warm/hot engine
2) open engine bay, and spray entire engine with windex
3) close hood
4) wash the rest of the car
5) before you dry the car, open the hood and spray the whole engine down with the hose
6) close hood
7) dry the rest of the car
8) open hood and dry the engine off
9) spray the engine with tire foam
10) close hood
11) wax car
12) open hood and wipe off excess tire foam that has pooled with clean rag
13) enjoy as people's jaws drop.
There were two problems with that procedure that I was warned about. One was that spraying the engine with a hose would screw up the electronics. I never had a problem, but thats not to say you should go at it with a pressure washer. I just used a standard hose nossle. The second was that the tire foam would prematurely crack the belts. But since I was a stickler for the engine bay looking good, I was also a stickler for chaning the belts out, so I never ran into that problem either.
In case you are interested, you can see the rest of the pics here:
http://www.brianrobak.com/gallery//album27
I changed my procedure up a little for the vette now with the zaino instead of the tire foam, but I still windex, cook, hose, cook, zaino, wipe. Done.
Micah
I would also be carful hosing down a hot engine hot and cold can make things break. I did some damage one and It cost me a lot of money.
I would avoid the Tire foam. Usually made of Silicones which can dry out the Rubber. Find a good polymer dressing. They will acutally preserve the rubber and its elasticily and will not leave an oil film
~One man’s opinion / observations ~
Engine detailing simply implies cleaning the engine compartment and applying protective products to wiring, vinyl and rubber hoses and shields. It’s not a difficult task, albeit the first time cleaning is a somewhat messy one. Then after the initial detailing it’s just a matter of maintenance.
It’s really an easy 45-60 minute task every 2-3 months, the benefits are to increase the resale value of the vehicle and also highlight any leaks that can be rectified prior to becoming a major service repair.
Heated water breaks down water-soluble soiling faster as it reduces overall chemical usage because it reduces the surface tension of the fibre. Heat acts as a catalyst promoting quicker reactions between chemicals and the soil.
· Remove any excess debris; leaves and etc form the hood, grille or air-vent openings.
· Spray all electrical connectors with WD40, which repels water.
· Use cling-film, Saran wrap elastic covers, or aluminium foil to cover any sensors, electrical black boxes, electrical devises that could cause an electrical short-circuits if subjected to water spray.
· This will not guarantee that you wont cause a problem when cleaning an engine bay but it will greatly reduce the risks.
· Start and run the engine to get it warm, not hot, this will enable the de-greaser to work more efficiently on a warm surface.
· Apply an engine de-greaser (Autoglym Engine Cleaner) by lightly spraying the lower parts of the engine first and then working upwards.
· Do not allow the de-greaser to dry or remain on painted surfaces, and be sure to dilute with water and dry with a cloth.
· For heavily soiled areas agitate with a parts brush and a diluted general purpose cleaner (P21S Total Auto Wash)
· When the grease and grime is dissolved and you’re ready to remove it, spray with a light pressure water hose.
· Allow the engine compartment to air dry and then thoroughly wipe down all accessible surfaces and then remove cling-film or aluminium foil.
· When everything is dry apply a vinyl/rubber protectant to hoses, shields and wires.
· Wipe off any excess with a clean cloth and apply a wax/sealant protection to painted surfaces.
Engine detailing leaves the engine compartment looking brand new. Mechanics realize that a clean engine belongs to someone who cares for their automobile, and will often take special care to undertake service repair work correctly.
~Hope this helps~
Experience unshared; is knowledge wasted…/
justadumbarchitect *so I question everything*
