Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Wax prep for NXT
Old Jul 6, 2004 | 11:12 AM
kluczenk's Avatar
kluczenk
Default Wax prep for NXT?
I recently bought some NXT and am planning to apply it soon. I also bought a Mothers claybar kit (claybar, showtime lube and carnauba cleaner wax). What are the recommended steps for prepping/waxing my car? I was planning on:
1. Washing car with light Dawn solution
2. Using the claybar/showtime to clay the entire car
3. Applying the NXT
Are there any other things I should be doing? Should I be using the Carnauba wax cleaner that came with the Mothers kit? Any help is appreciated.
Thanks!
[Modified by kluczenk, 12:39 PM 7/6/2004]
Old Jul 6, 2004 | 03:41 PM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
Default Re: Wax prep for NXT? (kluczenk)
~One man’s opinion / observations ~
NXT Tech Wax is a polymer that has been formulated with the ability to lightly clean the surface and eliminate fine swirls without marring. Like most synthetic waxes, Tech Wax likes to be applied to a clean surface that has been adequately prepped. Easy to use, and can be used by hand or machine (PC speed # 3-4).
The secret to the application of a polymer product is to apply it thin (super thin) fill a spray bottle and mist a foam pad then apply. First, and most importantly, thoroughly prepare your paint film surface. Wash, use detailer’s clay, polish and apply a pre-wax cleaner
The 3-step process you posted should be fine. Let us know how it works out.
~Hope this helps~
Experience unshared; is knowledge wasted…/ Jon
justadumbarchitect * so I question everything *
