Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Removing swirl marks?
Old Aug 8, 2004 | 02:48 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Removing swirl marks?
I have tried using color restorer, scratch remover, etc, but it does not take out the swirl marks on the car. the paint is in good condition except for the swirls. Is there a way to remove these? would adding another coat of clearcoat the car help?
Old Aug 8, 2004 | 03:02 PM
iceman_t1's Avatar
iceman_t1
I've got a black car and swirl marks would drive me absolutely nuts if it weren't for Zymol. When used as recommended, no swirl marks. Give it a try.
Old Aug 8, 2004 | 03:05 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
And then only use linear (not circular) motion when washing, cleaning and polishing the paint.
Old Aug 8, 2004 | 03:39 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
moved to "Car Care"
Old Aug 8, 2004 | 10:51 PM
ZaneO's Avatar
ZaneO
You can pay a professional to remove them or you can invest in a Porter Cable 7424 random orbital buffer.
Here is an article on the PC: http://www.bettercarcare.com/articles.php?articleId=47
Here's an article on how to fully detail your paint: http://www.bettercarcare.com/articles.php?articleId=28
Old Aug 8, 2004 | 11:23 PM
C5corvetteman's Avatar
C5corvetteman
NXT and Zaino's do not leave swirl marks at all. I have tried both and both are great. I have went to Zaion's because of the more optical look it gives on reflection. You must not go in a circular motion. Back and forth on the hood, roof, and lift. Up and down motion on the sides and doors. Put as think of a coat on possible too. Anyway, that is my $65.27 worth of an opinion.
Old Aug 8, 2004 | 11:52 PM
Southern Comfort's Avatar
Southern Comfort
and follow up with Novus # 1 http://forums.corvetteforum.com/showthread.php?t=879817
Old Aug 9, 2004 | 10:31 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
~One man’s opinion / observations ~
The products you are quoting (NXT, Zymol, and Zanio all contain fillers) that mask swirl marks but do not remove them (Z5 will only hide minor swirl marks)
A product applied over a properly prepared surface will only reflect what is underneath it.
85% prep, 5% product, 5% application methodology and the balance is in the ‘guy’ of the beholder
~Hope this helps ~
* justadumbarchitect so I question everything *
Experience unshared is knowledge wasted…/ Jon
Old Aug 9, 2004 | 12:11 PM
ZaneO's Avatar
ZaneO
THANK YOU!
It has very little to do with what last step product you put on your paint. That's only what people say when they don't know how to properly prep their finish. You need to properly clean and polish your paint before you worry about what wax/sealant to use on it.
Old Aug 9, 2004 | 12:28 PM
VETTEHEAD68's Avatar
VETTEHEAD68
Old Aug 10, 2004 | 02:48 PM
99RagTopp's Avatar
99RagTopp
Default Removing Swirls
Check out CMA's problem solving section for their step-by-step process and product recommendations for removing swirls. I've used the Menzerna stuff and it does work to remove the swirls, not just hide them. The URL is http://www.properautocare.com/problemsolving.html
To Removing swirl marks?
