Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Zanio
Old Sep 18, 2004 | 10:08 AM
ZaneO's Avatar
ZaneO
Originally Posted by LS WON
What is the cost of Zaino?
www.zainostore.com
Old Sep 18, 2004 | 03:55 PM
jrh009's Avatar
jrh009
clay bar, Z2, Zaino wash, applicators, mixing kit with accelerator 95. cdn or after you deduct our our Ontario taxes, 80.00 cdn = 50. ame
Old Sep 19, 2004 | 03:58 AM
LS WON's Avatar
LS WON
Originally Posted by agentf1
If you don't want to use Dawn use 50/50 Isopryl Alcohol and water to remove wax. Anybody that says Zaino is alot of work is doing something wrong. Sometimes the prep is alot of work but that should be done before you use ANYTHING.
Old Sep 19, 2004 | 04:00 AM
LS WON's Avatar
LS WON
Originally Posted by CHRIS NJ C5
nothing better then Zaino
DRANO
Old Sep 19, 2004 | 04:01 AM
LS WON's Avatar
LS WON
Originally Posted by ZaneO
Thanks wow this is alot of reading like alot of homework to do.
Old Sep 19, 2004 | 09:59 AM
Zaino guy's Avatar
Zaino guy
You might check with ira@lazaino.com
Old Sep 19, 2004 | 11:01 AM
ZaneO's Avatar
ZaneO
If you really want to do your homework, try this one: www.autopia.org/forums
Old Sep 20, 2004 | 06:44 PM
Kevin V's Avatar
Kevin V
To me, Zaino is easier and faster to use than anything else I've used in over 30 years. My son can do an entire application, drying, removal and Z6'ing in about 45 minutes. Since it is so durable it makes keeping the car clean very easy. You don't have to build up alot of coats, just a couple to make sure you have good coverage is all you need. Then add more layers just when you feel like it or to deepen the shine and improve the protection since it stacks.
Old Sep 21, 2004 | 09:44 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
~One mans opinion / observations~
Zanio was voted the number one synthetic polymer sealant by an independent testing body
(Guru Reports) its application process has a small learning curve, but once mastered the results are well worthwhile. This is the product I use for the preparation of concourse vehicles (or any vehicle that requires a ‘show car’ shine
Zanio is a synthetic polymer wax ( although its called a polish it contains no abrasives) a compromise between a polymer sealant and a natural wax. The polymers do not require a lengthy cross-link (cure) time as ZFX is formulated to accelerate the time requirements. Z-2 produces the most gloss of the two synthetic waxes (although they’re labelled as polishes) it is more optically clear then Z-5 and will highlight any surface imperfections, whereas Z-5 will ‘hide’ very minor surface imperfections with fillers. Z-3 is a ‘polish’ for single stage (non-clear coated) paint.
For the ultimate in show car appearance and total protection, here are the Zaino products that you'll need to make it happen. Included in the Zaino Show Car Kit are everything pictured including the following:
ZFX™ Flash Cure Accelerator Additive
Z-2™ Show Car Polish for Clear Coated Car Finishes
Z-5™ Show Car Polish for Swirl Marks and Fine Scratches
Z-6™ Ultra Clean Gloss Enhancer Spray
Z-7™ Show Car Wash
Z-18™ ClayBar
Code: ZKIT-1
Price:$84.70US
Shipping Weight: 5.40 pounds
~Hope this helps~
Knowledge unshared is experience wasted
justadumbarchitect / so I question everything/ Jon
