Removing Buffer Marks
For removing them, I recommend an orbital buffer
It needs to be a Porter Cable or something as powerful as that. This will be the most effective and most efficient way to get the job done.Claybars will never remove surface imperfections such as swirls. They only remove contaminants from the paint.
Meguiar's ScratchX is a nice product for use by hand, but you may never get your paint perfect by hand.
With your car being black, I can see the PC as an extremely worthwhile investment that you will need to use multiple times during your car's life.
Here is a good article to read on using a PC: http://www.bettercarcare.com/articles.php?articleId=47
Remember also that things like quality mitts, towels, and applicators are very important to maintaining a swirl and marr-free finish. I recommend these vendors for great products: www.pakshak.com and www.exceldetail.com
Feel free to ask any questions you may have regarding anything I've said
I buy my supplies from:
www.autogeek.net
www.autopia-carcare.com
www.topoftheline.com
www.detailersparadise.com carries Einszett.
They are a great range of polishes-
Ultra Paint Polish (>1200 grit) Yellow
Is a medium cut compound used for paint renovation and the removal of heavy surface imperfections, swirl marks and surface etching and abrasions.
Paint Polish (1500 grit) Green
Is a general purpose polish and paint surface cleaner for the removal of dirt and grime from the paint pores, and medium to light surface abrasions.
Metallic Polish (2000 grit) Red
Is ideal as a swirl mark remover for the removal of minor surface abrasions, light spider webbing, swirl marks, and etc.
Iz Einzett polishes can be applied by hand, or machine polisher. Application of the Ultra Paint Polish you will obtain the best results with a high speed rotary, as heat is required to soften the paint …
~Hope this helps~
Knowledge unshared is experience wasted
justadumbarchitect / so I question everything/ Jon
