Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Polishing Technique
Old Oct 7, 2004 | 02:52 PM
94AdmiralCoupe's Avatar
94AdmiralCoupe
Default Polishing Technique
I have read that polish should be applied in a back and forth motion on horizontal surfaces (hood) and in an up and down motion on vertical surfaces (doors,fenders). I assume this should be done using short strokes?
Should it be buffed off using the same motion?
How much pressure should be used when applying polish and buffing?
I realize that doesn't sound good, but there really is no inuendo intended.
Old Oct 7, 2004 | 03:06 PM
ZaneO's Avatar
ZaneO
If your car is cleaned properly and you are using quality materials to apply and remove products, it shouldn't really matter the motion used. Use enough pressure to completely and uniformly cover the area.
Old Oct 7, 2004 | 03:17 PM
Silver2002's Avatar
Silver2002
Cruise-In III Veteran
St. Jude Contributor
Check out: http://www.zainostore.com/Merchant2/...S&Store_Code=Z It will give you an explanation of why to use the different motions.
Old Oct 8, 2004 | 11:03 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
~One mans opinion / observations~
Q: I have read that polish should be applied in a back and forth motion on horizontal surfaces (hood) and in an up and down motion on vertical surfaces (doors, fenders). I assume this should be done using short strokes?
A: This application technique affects the paints optical properties by optimizing light refraction and the reflectivity of the bodylines and contours of the vehicle.
Q: Should it be buffed off using the same motion?
A: Yes
Q: How much pressure should be used when applying polish and buffing?
A: Polish- a medium (not heavy) pressure should be maintained (when using a machine it’s weight exerts enough pressure) do not use circular motions with any abrasive, as it will add swirl marks.
Wax- again a medium light pressure is sufficient as all your trying to do is apply the wax to the surface, circular motions are OK with wax providing it doesn’t contain abrasives (i.e. a cleaner wax)
Buffing- a medium light pressure is sufficient
~Hope this helps~
Knowledge unshared is experience wasted
justadumbarchitect / so I question everything/ Jon
Old Oct 8, 2004 | 12:21 PM
ZaneO's Avatar
ZaneO
That is Zaino specific advice. You can't visually tell a difference.
Old Oct 8, 2004 | 09:28 PM
Z0SLIK's Avatar
Z0SLIK
Either way is fine. Just don't apply to much pressure. You will find that everyone has a different technique. It's up to you to develope your own.
Old Oct 10, 2004 | 09:37 AM
denali's Avatar
denali
Check out this sight.http://www.thedetailingbible.com .It will answer all your questions.
To Polishing Technique
