Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Cleaning Engine compartment
Old Jan 23, 2005 | 08:37 PM
mpdillon's Avatar
mpdillon
Cruising
Default Cleaning Engine compartment
I have about 41K on my 2002 Z06. The engine compartment is starting to look a little "dusty". Does anyone have any suggestions for cleaning. As you know it is a mix of plastic and metal. I am concerned a degreaer would harm the plastic.
Old Jan 23, 2005 | 09:00 PM
ZaneO's Avatar
ZaneO
There is a search button.
There is also a VERY similar thread on this very page.
Not trying to be rude, but it's really not hard to find this information.
Old Jan 23, 2005 | 10:22 PM
KnightRider02's Avatar
KnightRider02
I agree there are many threads on engine compartment cleaning/detailing...and yes there is one recently pposted because I replied to it. But since we are in the aftermath of a massive snow storm I will take the time to share with you my advice.
1. Make sure your engine is warm. Keep it running through out the entire cleaning process. Also, make sure you cover vital parts such as the battery/all the wiring there. I find a large garbage bag works very well.
2. There are many engine cleaners out there. My personal favorite is Griots Garage Engine Cleaner. Spray your engine down with water. Clean in small areas. Spray a small area down, let it sit. Use a rag/brush whatever you want to clean the area. Hose off when your done. Working in small areas is better because you can take your time to get into those nooks and crannies.
3. To make those rubber hoses and plastic parts new again there are alot of options. A bottle of Armor All will work fine for this. There are alot of other products out there...use what works for you. 303 Aerospace Protectant also works great for this. Personally I use Mothers Back To Black on all rubber hoses. Gives them a very nice natural clean look to them.
This is only my 2 cents. There are tons of products out there. Use what has worked for you in the past and you will be fine. Hope this helps ya.
Old Jan 24, 2005 | 11:05 AM
cazorp's Avatar
cazorp
CD2 is a very good product and easy to use once your have your motor and compartment clean.
Old Jan 24, 2005 | 12:11 PM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
·Remove any excess debris; leaves and etc form the hood, grille or air-vent openings.
·Spray all electrical connectors with WD40, which repels water.
·Use cling-film or Saran wrap elastic covers to cover any sensors, electrical black boxes, electrical devises that could cause an electrical short-circuits if subjected to water spray.
·This will not guarantee that you wont cause a problem when cleaning an engine bay but it will greatly reduce the risks.
Start and run the engine to get it warm, not hot, this will enable the de-greaser to work more efficiently on a warm surface.
~Hope this helps~
JonM
Old Jan 24, 2005 | 10:18 PM
LS WON's Avatar
LS WON
Default This is so correct
~Hope this helps~
JonM
I found out the hard way.
To Cleaning Engine compartment
