C5 A4 Launch question
Mar 6, 2005 | 09:06 PM
I have a stock C5 with an automatic. What is the fastest way to launch the car at the strip?
Mar 6, 2005 | 09:26 PM
I had my best results flooring it from an idle.
Mar 6, 2005 | 09:39 PM
St. Jude Donor '07-'12, '20
Quote:
I find the same thing.
Bob
Mar 7, 2005 | 12:26 PM
Foot on brake and rev it just a liitle, just so it doesnt slam the drive train.
Mar 10, 2005 | 02:55 AM
Mar 10, 2005 | 08:14 PM
Mar 10, 2005 | 08:29 PM
St. Jude Donor '05
Foot on the brake, bring up the idle and gooooooooooooooooooooooo. On the third yellow!
Mar 14, 2005 | 10:50 PM
I've had my best runs when I foot brake it up around 1800 RPM and then roll into the throttle. little to no wheel spin.
Mar 15, 2005 | 12:16 PM
Cruise-In II & IV Veteran
CI VI Drag Champ!
You will have to experiment with both methods, leaving off idle and brake torquing it.
A lot depends on your tires too. If you are using the run flats, punching off idle might not work
Mar 16, 2005 | 08:55 AM
St. Jude Donor '08-'09
Does anyone have a link to the webpage that had an explanation on how the tree lights work? I'm going there this weekend for the first time and want to get some more info. See you guys there!
