Hi. I have an Activator II and think I have a problem.
I tow a car on an open trailer weighing about 5000 lbs total.
When I first drive off the trailer brake works fine.
After about 15 minutes of driving, when I apply the brake pedal on the truck, I get a flashing OL. I am not sure how it could be overloaded as no weight is added only driving.
I tow with a 2003 Avalanche 1500.
Thanks for your help
I have towed heavy for years and I use a Tekonsha brake controller. Never any problems. If your brakes work OK I would ignore it.
Usually brakes are tighter when you first start driving and tend to loosen up. I then adjust the controller to be a little more aggresive.
Bob
Edit: I just looked at the unit you have. Overload indicates a short or low power and is not related to weight. You have a wiring problem.
I may switch to one of those Tekonsha's That is the Prodigy right?
Right, but I don't think it will fix your problem. From the website it says you have a short or low power. You may just need to clean the connector contacts or low power could be a poor ground.
Ours was doing the same thing. It turned out to be a wire that was cut running across the axle. It was shorting out intermittently. Trace all your wiring and I bet you will find a cut somewhere.
