Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Time Slip Comparison ?????
Old Apr 28, 2005 | 01:28 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Time Slip Comparison ?????
Ok guy's made 2 changes. Went from SS3200 converter to a SS3600 and dropped air pressure from 25lbs hot to 20lbs hot. Temp outside was much warmer last night (I have no idea how to find actual temps for the dates) Best 60' and best ET Lost 2+mph Here's last time I raced and last nights time slips for comparison. Open to opinions, of which I have recieved a few already.
Old Apr 28, 2005 | 01:38 PM
VETDRMS's Avatar
VETDRMS
1) A higher stall converter will have more slip
2) Lowering the air pressure will increase rolling resistence
Old Apr 28, 2005 | 03:58 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
You win with ET, mph means nothing.
Old Apr 28, 2005 | 05:00 PM
chaase's Avatar
chaase
St. Jude Donor '12
I believe that it is normal, sooner to 60', lower MPH.
Chris
Old Apr 28, 2005 | 11:56 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Cooler air + lower humidity = more HP = higher trap speed and vice versa...
Old Apr 29, 2005 | 03:11 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
NCM Ambassador
Here is what I use to find temps & stuff for DA, pretty acurate too!............
http://www.wunderground.com/index.html
Put in your zip and go from there.........
Here are 2 places to .........figure your DA pretty close.
http://wahiduddin.net/calc/calc_da.htm
or
http://www.nawcwpns.navy.mil/~weathe...acalc_stnp.htm
Even if its off, its off by the same amount for each day but a good comparison other than a swag
Old Apr 29, 2005 | 06:05 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Bob, there is nothing wrong with those slips.
I see the "win" pointing to your side each time.
Old Apr 29, 2005 | 06:49 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
These might help
http://www.modulardepot.com/density.php
Moroso's Elevation 6'. This is what I got when I plugged in your nbrs using 6:53PM, March 11, 2005.
Density Altitude = 739 feet ET MPH
Uncorrected 12.092 @ 114.85
Corrected 12.00 @ 115.74
For April 28, 2005 at 7:53PM
Density Altitude = 1010 feet ET MPH
Uncorrected 12.068 @ 112.89
Corrected 11.94 @ 114.1
You may want to dbl check this as I did this rather quickly.
The initial results don't have the torque converter change giving you much.
Old Apr 30, 2005 | 02:17 PM
taaz024's Avatar
taaz024
Good runs Bob!! I would raise the pressures back up to about 25. That's where I run and it helps with speed and control going down the track. The M/T's will grip at either pressure, so you will not lose anything off the line. On second thought, try raising the pressure to about 60 psi. I like my position in points, lol.
Old Apr 30, 2005 | 04:27 PM
16Again's Avatar
16Again
Thanks for all the advice and help guy's.
EB2003 Check your PM
Bob
Old Apr 30, 2005 | 05:31 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Was the weather very close for the two races? I know my Vette will loose ET when the hum. is above 65%, Even though the weather station will predict a quicker ET.
Tire pressures sounds a little low.
I think all is in order with your car. I would make more passes to make sure it is consistant.
Old Apr 30, 2005 | 06:28 PM
16Again's Avatar
16Again
Actually Rob it was 23 degrees warmer this time. I'm going to bump the tire pressure back up to 24lbs and see if it still hooks. With the SS3200 converter I had no problem with the ET Streets @ 24-26 lbs. I think the lower pressure in the tires and the warmer temps hurt me a little. Going back this Wednesday to test a little more.
To Time Slip Comparison ?????
