I never disagree...I don't have a clue about 18" tires...I will say that your rim size generally denotes how much meat you can fit...check with the DR manufacturer and they will tell you real quick...
Craig, the Nittos are the hardest compount drag radial out there and I don't know many regular bracket racers that have stayed with them when trying them.
"Regular" being the operative word there.
Fuzzy uses them and I heard he's constipated. Or maybe just irregular. Well we KNOW he never races anymore!!
Are you sure you want to go Nitto?
If Craig is going to put DR's on as daily drivers, Nitto's are the way to go..we get a lot of heavy rain down here....they will not give you the "snappy" short times but they have been very consistent on my car with no spinning out of the hole...that's the best one can ask from a daily driven tire...
You haven't driven in so long you don't know what a "snappy short time" is.
I still haven't made up my mind, I don't want to change tires every week. Right now I'm using run flats, they work pretty good but every once in a while they will spin a little bit. So i figured i just need a little more traction
