Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Need Help On Launch
Old May 15, 2005 | 06:59 AM
BIGMAC's Avatar
BIGMAC
Default Need Help On Launch
With over-the-winter mods. I was hoping for 12.8 but only got 13.02 on first day out compared to a best 13.4 previously. I run BFG DR's - but 60' time was 2.0- only slightly better than with 2.73 rear, no headers or tune, and run-flats! I don't have line-lock so big burn outs are not possible. I have a stock TC so I break torque to 1500RPM at launch. My brother who is an avid bracket racer tells me a 13.0 with a 2.0 60' means I have way too much wheel spin despite the DR's and that I have the potential to go way into the 12's with a decent 60' time.
What is the optimum tire pressure to run?
What is the best burnout technique for a A4 with no line-lock?
Should I lower launch RPM or go from an idle?
Any other tips?
Thanks in advance!
Old May 15, 2005 | 11:53 AM
CFI-EFI's Avatar
CFI-EFI
ARE you getting wheel spin? There is no need for a line lock inorder to be able to do a big burn out, if desired. Hold the car with the brakes and jump on the gas. As soon as you get the R's up, shift to second gear to increase the wheel speed. I do my burn outs dry, no water, and I can smoke 'em as much as I want with no line lock. The "correct" tire pressure is a matter of experimentation. A lower launch rpm should reduce wheel spin, if you have it, if you can't eliminate it by airing down.
RACE ON!!!
Old May 15, 2005 | 01:01 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Mac, did I read right? You have stock converter?
That be the problem brother.
Is there a reason you are running stock converter?
I run BFGs around 20 psi. Line lock will help
Old May 19, 2005 | 07:55 AM
FMF C5's Avatar
FMF C5
drop your tire pressure down to 18
Old May 19, 2005 | 08:55 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Originally Posted by BIGMAC
With over-the-winter mods. I was hoping for 12.8 but only got 13.02 on first day out compared to a best 13.4 previously. I run BFG DR's - but 60' time was 2.0- only slightly better than with 2.73 rear, no headers or tune, and run-flats! I don't have line-lock so big burn outs are not possible. I have a stock TC so I break torque to 1500RPM at launch. My brother who is an avid bracket racer tells me a 13.0 with a 2.0 60' means I have way too much wheel spin despite the DR's and that I have the potential to go way into the 12's with a decent 60' time.What is the optimum tire pressure to run?
Any other tips?Thanks in advance!
My best 60' in the 00' coupe was a 1.91 with nitto 275/40/17 street tires.......stock TC & 3.15. gear. 8 second burn out
I launch from a dead idle after loading the drive train to 1100 rpms then back off to idle.
Pressure in my drs is 19 psi hot on my other cars.
W/o a TC upgrade your 60's will only go so low.....1.90 is about it on a stock 2.73 TC
Old May 19, 2005 | 08:56 AM
isosceles's Avatar
isosceles
Thanks in advance!
that could be your problem but not necessarily. With my 383 I turned a best of 12.9 with a 2.0x 60' time with NO wheel spin. That same motor propelled GrandsportC3's 68 to 11.67.
The differences? My car is 500lbs heavier, 3.36 gears to his 3.70, and my 1400 launch rpm to his 3000. However, my MPH was a little higher than normal for a 12.9 run. Gears and launch RPM make a BIG difference.
Old May 19, 2005 | 10:15 AM
Special K's Avatar
Special K
12.9? Sandbagger, that's what you are. Hey guys, he's running a 14.5 dial. Your brakes must be wearing out quickly.
Thanks Steve. I've never run an auto before and I find that very interesting that you preload and then launch from idle. I'll try that. Was hoping to meet you last week. How did the vacation go?
Old May 19, 2005 | 10:57 AM
Cruise-In V Veteran
NCM Ambassador
I have ALWAYS found this to work for me in any vehicle.........very consistant too
To much going on to come to Fl, vacation went well.... thanks for asking. My pit crew is released for full time golf!
Going to CI?
Old May 19, 2005 | 12:57 PM
Special K's Avatar
Special K
Going to CI?
Going to CI? I'm working on it. Are you referring to the Big Mouth?
Edit.
Are you loading at prestage, going in and staging at 1100 and then unloading? I would not want to do all that after staging.
Old May 19, 2005 | 06:16 PM
Cruise-In V Veteran
NCM Ambassador
I ment Cruise in next week Bob.......Gott ya big time! The CAI that you trust is a good move though
AS for the staging.......I prestage, ajust my stuff , pull up and stage. As my LH foot is already on the brake, its nothing to bring the revs up to ~1100 and back to idle just as the yellows are coming down and BAM launch time! This also works for me on the pro tree
For me this gets me consistant 1.52-1.55 60's in the 97' and 1.72-1.73 60's in the 00' vert. the 00' coupe has the stock TC & 3.15 gear so its slow outa-the-hole
Old May 19, 2005 | 07:04 PM
Special K's Avatar
Special K
That would screw me up big time. Like I said I'll try it but I'll run er up at pre stage, bump in and then drop to idle. You're much more intelligent than I, my mind couldn't handle all that after staging. I'll let you know how it works next week.
We're not making any cruises next week. You talking about the boys down south?
Old May 19, 2005 | 07:10 PM
BLACK SHARK's Avatar
BLACK SHARK
From: In the shop most of the time,,, And it BEER TIME somewhere
RACE ON!!!
Just a question,,, are your back brakes working at all???????
Old May 19, 2005 | 07:50 PM
Special K's Avatar
Special K
Back brakes and tires. Does his burnout dry.
Old May 20, 2005 | 08:42 AM
Cruise-In V Veteran
NCM Ambassador
I KNOW some folks would disagree with ya on that one.
Do try it your way.......each car/drive is different.
As for the CI.........I mean the one at Bowling Green, KY. starting the 25th!
http://forums.corvetteforum.com/show...93&forum_id=15
Old May 20, 2005 | 08:58 AM
Special K's Avatar
Special K
Not gonna make it. Mary says I've spent all the money and need to think about going back to work. Woman is a slave driver.
Have you seen my blue chair?
Old May 20, 2005 | 10:03 AM
Cruise-In V Veteran
NCM Ambassador
Too bad..........by her her own Vette
As for the chair...........dark blue............4 legs.............nice and plush...........nope haven't seen it, but I am in a chair right now
Old May 20, 2005 | 10:41 AM
Special K's Avatar
Special K
I tried that. Tracy Lewis has a great 2000 really set up but she said no. Guess you know who the boss is.
To Need Help On Launch
