Alignment for drag racing..?
This is the right rear looking forward. The rubber is worn to the left, as if it was dragged sideways. The drivers side is a mirror image.
Common sense tells me I'd need toe-out in rear for this to happen during a burnout. But I have zero toe in rear. Maybe I'm getting toe out during squat?
I'm concerned that there's a slight slip angle which is hurting traction. Or am I just nuts?
(20 lbs pressure, Yokohama AVS ES100, best 60ft = 2.06s, if that helps any)
Naaaa J/K I don't think it will hurt your traction off the line.. however if it is out it WILL kill a set of tires real soon by driving it long distances on the street.
Whenever I have my rear end out for any reason I always get it realigned.. no special alignment just back to factory specs.
good luck
How do you know the toe in is correct? You need at least three alignment shops to verify that.
If at least two of them agree on the toe in then we should spread powder on the ground and drive through it. Examine the tread pattern and see if it looks OK. This is a judgement call and you're going to need other opinions. Suggest you invite all guys that participate in the drag section.
Drag radials would solve more than one problem
But back to the subject at hand, have you found that a burnout on street tires helps your sixty ft times? The reason I ask is that conventional wisdom states that a burnout helps very little on street tires.
I do it to clean the tires off. I figure if I can spin them all the way up to the staging lights its less crap to pickup while rolling up their on hot tires. Also the rolling burnout doesn't heat the tires up as much, since it's always in contact with cold pavement, unlike a standing burnout. If I'm forced to drive through the water box, I burn them a bit longer to make sure they're dry.
I won't bother with drag radials until I get all I can out of these tires. The first run on these tires was ice cold, brand new ~10 miles on them, and they sucked bigtime.
I wonder if the wierd treadwear could be due to a combination of camber and tire pressure? There's no way to guess at how much slip angle is going on.
I measured the alignment the old fashioned way, with two sticks and a tape measure. Also used a laser level to check it. Toe is easy to measure if you know 10th grade math.
