Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Drag front suspension question...
Old Aug 13, 2005 | 05:36 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Drag front suspension question...
I've noticed in several videos (including my latest video) that my wheels come off the ground, then the car bounces and the wheels come off the ground again... Could this be because my shocks are set to 80/20?? If I'll switch them to 90/10, could the 2nd bounce go away??
http://www.corvetteforum.net/c3/gran...otowheelie.wmv
Old Aug 13, 2005 | 06:44 PM
Special K's Avatar
Special K
Springs Oliver, think springs.
Old Aug 13, 2005 | 08:44 PM
GrandSportC3
Nobody makes direct fit drag springs for C3's .. I went with '65 small block springs because they are the softest springs available... I first want to see if it'll make a difference when switching to the 90/10 setting..
Old Aug 13, 2005 | 09:19 PM
jpee's Avatar
jpee
I watched the video, & see what you mean.. but I don't think its hurting your ET or traction..
It might be serious if you were lifting the front 1-2 FEET and unloading the rear when it came down & bounced,, but it does not appear to be unloading the rear..
Do you think you are feeling the rear tires breaking loose when it bounces ?
Old Aug 13, 2005 | 09:37 PM
GrandSportC3
The car hooks perfectly..
However, I haven't launched with the transbrake yet.. Right now, I'm pulling the wheels 1 - 3 inches off the ground but once I use the transbrake, I expect to pull them a foot or so off the ground.... I don't really want to have a second 1 foot bounce
Looking closely at the video, the second bounce is almost as high as the initial lift of the front wheels...
Old Aug 13, 2005 | 09:39 PM
GrandSportC3
I also noticed that my front stays up pretty high during I'm going down the track... Maybe I should go with not so tall front tires.. Right now I'm using 28 x 13.5 - 15 rear slicks and 28 x 4.5 - 15 front tires.. Maybe I should go with the 26 x 4.5 - 15 front tires.. That would lower the front and could reduce drag... but I'm not 100% sure...
Old Aug 13, 2005 | 10:25 PM
Special K's Avatar
Special K
One last suggestion Oliver. Take it to someone that knows what they're doing. Call Tracy and I'm sure he knows some good suspension people around there.
It will save you money over the long haul.
Old Aug 13, 2005 | 10:31 PM
GrandSportC3
Well, I'll first try to set my front suspension to 90/10 and see what is going to happen...
Old Aug 13, 2005 | 10:41 PM
Special K's Avatar
Special K
I knew you would. Good luck Oliver. Hope it works.
Old Aug 14, 2005 | 01:11 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
65 small block springs, QA1 SHOCKS...................trust me on this one
Old Aug 14, 2005 | 03:33 PM
GrandSportC3
I do have '65 small block front springs... but Competition Engineering adjustable shocks...
Old Aug 14, 2005 | 04:43 PM
_twisted_'s Avatar
_twisted_
Isnt it rebound that is causing the second bounce?
I would think 70/30 would reduce the bounce.
And 90/10 would most definitly have the front riding high the whole track under heavy acceleration, thus 70/30 might level it out better but hurt your et with a loss of traction.
Can your shocks do 70/30? If so I would give that a try and watch the video of a few runs.
Old Aug 14, 2005 | 05:20 PM
GrandSportC3
I could adjust them to 70/30 but I'm worried that I won't get enough weight transfer so that I'll hook...
Old Aug 14, 2005 | 06:47 PM
markshaw70redBB's Avatar
markshaw70redBB
I also experience the bounce with my '70 big block. I run the CE shocks on 90/10 to keep the weight transfer maximized. I also have the long bump stops in the rear.
I've been consulting with Tom's Differentials for several years to get help improving the launch. I can get a 1.36 60' time when I leave at 4000 rpm using my full shot of nitrous. I can carry the front wheels about 12" off the ground all the way past the tree. (9.81, 140 mph). It lands smoothly and doesn't rebound back up. That's a launch I don't do all the time. More often, I leave at 3800 rpm, hook perfectly and leave straight. When I watch the video in super slo mo I can see the bounce after the front tires lift about 3 inches for a few feet.
Tom's advice is to add leaves to the rear spring until the transfer doesn't drive the bump stops down on to the top of the trailing arms. I have added two additional leaves (total of 9 now) and use QA1 shocks dialed all the way up. Even then, I notice the 2nd bounce but I don't think I'm unloading the suspension energy.
Keep us posted on your results. I'm curious what will happen if you dial 70/30 instead of the 90/10.
Old Aug 14, 2005 | 07:16 PM
GrandSportC3
I'm far from hitting the rear bump stops.. My rear spring is sooo stiff.. I don't get more than 1/2 inch travel... and I have my rear sit very high..
Old Aug 15, 2005 | 12:49 AM
LOTAHP's Avatar
LOTAHP
Don't even know why he bothered asking???
Old Aug 15, 2005 | 07:55 PM
red79vette454's Avatar
red79vette454
What rear tire and gear are you using to get 1.36 60' and go 140MPH?
We are looking at that 9 second pass with nitrous big block but with 27" tire and 4.33 gears I don't know if we'll have enough RPM to go that speed.
To Drag front suspension question...
Old Aug 15, 2005 | 10:10 PM
The Green Rocket's Avatar
The Green Rocket
Check out
http://www.geocities.com/kdslaby/Tec..._Glossary.html
Most likely you will need more shock rebound not less, or you need to find some way of increasing front end travel to avoid the snap unload (when your front end drops too quickly it is actually decreasing the load on your rear tires). What you want is a more controlled lift and slow drop. Alternatively, you may find improved results by limiting the front wheel travel and converting the lifting motion more efficiently into forward motion.
Thomas
Old Aug 15, 2005 | 10:17 PM
_twisted_'s Avatar
_twisted_
To get that kind of performance I would think the shock would need a method of adj the compression and rebound dampening right?
Old Aug 15, 2005 | 10:43 PM
GrandSportC3
Originally Posted by The Green Rocket
Check out
Thomas
Great link!!
I might try 90/10 and 70/30 setting and will see what happens.. The 90/10 setup should allow the wheels to come off the ground higher and should dampen better when coming down...
