Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
C4 Half shaft problem.
Old Aug 27, 2005 | 09:28 PM
rodj's Avatar
rodj
Default C4 Half shaft problem.
Posted over in C4 Tech , not much response.
Am destroying the inside of the half shaft yoke where the uni fits on stock D44 halfshafts.
Has raised lip of alum ,paper thin approx 3mm high
Have only done 50 passes on street tyres with zz4 cammed 95K L98.( 1.84s)
All new components , have also taken out the camber arm bushes (VBP poly ).
Time for alum bushes and steel haftshafts?
Down here in the colonies , not so easy as ringing up Denny's for some new parts , will have to get made here.
Any one else had this problem?
Am building 383 for next season and if I am doing this damage with stocker doubt will get very far.
Old Aug 27, 2005 | 09:38 PM
_twisted_'s Avatar
_twisted_
what brand universals are you using(or stuck using)?
Old Aug 27, 2005 | 11:05 PM
rodj's Avatar
rodj
Have brand new Brute Force , unable to get recommended Spicers in correct size down here.
RH unis have more play (minimal ) than LH ones but both halfshafts have the pounding out of the cup seat on the inside of the yoke.
The cups were as tight coming out as going in .
The damage in fairly uniform around the hole, not only on the front /rear faces as you would expect from rotational loads.
The fact that I have destroyed the camber bushes indicates to me that I am generating a lot of side loading as in the tyre being pulled in and out on rear squat because the trailing arm bushes show no sign of wear reasonably expected from the rotational forces of the diff twisting against the car.
Old Aug 28, 2005 | 01:21 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I have a box full of old 1/2 shafts many with that condition. I'm having a solid axel installed in mine. End of my problem. Good luck with your.
Old Aug 28, 2005 | 01:50 AM
rodj's Avatar
rodj
How far did you run them until swapping them out?
Are you running solid bushes in the camber arm?
Have open track day (unlimited runs ) next Sun that I want to do some test and tune at , then car can stay in shed until new engine ready.
Hope everytning hangs together.
Old Aug 28, 2005 | 02:11 AM
Ned Erkman's Avatar
Ned Erkman
Default IRS expert
One of the most knowledgeable Corvette rear end experts is Dennis McDonald and he enjoys helping C4 owners with their IRS problems.
His C4 just ran a 9.2 second ET at 154 mph with an independent rear suspension. The car runs 1.38 60ft times with an IRS.
You can check out his purple C4 in the Supercar Speed News section of the American Supercar challenge.
http://www.rollingthunderz.com/ascc.html
If you want to get in contact with him by telephone you can e-mail me and I can give you his number. My e-mail is at the bottom of the ASCC web site.
Ned Erkman
Old Aug 28, 2005 | 10:59 AM
Eric Fischer's Avatar
Eric Fischer
I have had to replace the u-joints twice in the last year in my Dad's C4. Luckily there hasn't been any damage to the halfshafts though...
Old Aug 28, 2005 | 12:29 PM
_twisted_'s Avatar
_twisted_
Here is a link from a thread I read into yesterday, it offers some great discussion and experience. It originally was a 60' time thread that evolved into C4 IRS setups and shortcomings.
Since you went further then the half shaft question, I think you can find what your looking for here
To C4 Half shaft problem.
