The individual in the white car stated his best RT that day was .038. Let's assume he had an .05 this run. What do you think the RT was for the yellow car?
We all do it. Maybe not quite that bad but I know this individual is new at this and is working on it.
A month ago I staged and then remembered to flip a switch I normally do when I prestage. I looked down, flipped it and when I looked up the tree had already started. I think I had a .185 RT.
Thanks for the heads up......electronics are illegal in our class. No new rule needed
so what RT is considered good/ desirable, I know that you want as low as possible, but at what point are you pushing the limits of red lighting?
Any suggestions for timing the lights? (I used third yellow, but I think I'd have to jump that to get faster).
I think most would like to be in the .0teens. The goal you shoot for is dependent on the level competition as well. For example, in our Corvette Challenge an .0thirty's average will win you a fair amount of rounds.
However on other, more series bracket racing classes and .0thirties average well get you an early trip home very often.
Below is the slip......
It is what it is.........
4/10th+ on the tree.......
3.5/10ths on the 60'.......
Mine even in +2000 da was still over 26mph on the big end
Hehehehehe...JJ gonna get ya Bob. My side bet is on her
Did you see the PM I sent her? I said I knew payback was hell and I knew it was coming. You, on the other hand just blew her cover. I wonder what's in store for you?
