Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
need drags help
Old Oct 31, 2005 | 09:37 PM
rugby!'s Avatar
rugby!
Default need drags help
i have 91 and i need tires to use on the track only. some use nittro555 are these good any other ideas?
Old Oct 31, 2005 | 09:39 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
BFG Drag radial or Mickey Thompson drag radial will work.
Depending on the wheel you uses either a 275.40/17 or 315 if you use an 11 inch wide wheel.
If you are running high powered stick car, look for ET Steets bias ply.
Old Oct 31, 2005 | 09:54 PM
Special K's Avatar
Special K
I'm running 315 on a 9.5 wheel and it works. I would prefer an 11.0 wheel.
Old Oct 31, 2005 | 10:09 PM
_twisted_'s Avatar
_twisted_
I just started using BFG DR and I am a believer now!
Old Oct 31, 2005 | 11:04 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I need a little more info..do you have an A4 or a MN6?...if you have an A4, do you still have the Dana 36 differential?...what gears do you have?...are you racing your vette once a year at the drag strip or once a week?...I ask because your answers make a huge difference on what tires you can use...if you plan to race regularly, and you have a Dana 36, you can expect to break your differential if you run sticky tires...it will only be a matter of when, not if, it will break...
Old Nov 7, 2005 | 07:25 PM
rugby!'s Avatar
rugby!
i have a 383 with a dana 36 with 2.59 gears. i may be getting 3.07 in the spring. i plan to run on the track 6 times a year. and it is an auto. i will just put the tires on when i go to the track. thanks for the help
To need drags help
