Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Power vs Durability?
Old Dec 1, 2005 | 03:39 AM
chad4msu's Avatar
chad4msu
Default Power vs Durability?
At what point, horsepower-wise, do I need to be concerned about breaking stuff in my '02 Z? (e.g. output shaft, rear end, etc)
I am getting MT 275 40/17's put on tomorrow so I was just wondering...
I'm mostly stock - see sig.
Also, where can I find some good information on launching techniques?
Old Dec 1, 2005 | 06:03 AM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
I've seen guys break drive-train components on the factory tires. Your new tires will definitely put more stress on things so the risk of breaking something will increase. Frequent hard launches will take a toll, it's just a matter of time. Some guys are lucky, some aren't. You should consider a hardened output shaft (long) and a DTE strut brace. Also, the factory clutch will likely give you trouble.
Old Dec 1, 2005 | 04:45 PM
chad4msu's Avatar
chad4msu
where can I find good prices on that stuff?
Old Dec 1, 2005 | 06:54 PM
JerryL's Avatar
JerryL
Call Dave at Cartek (Garwood, NJ). 908-317-4496. Tell him Jerry sent you.
Old Dec 1, 2005 | 07:29 PM
chad4msu's Avatar
chad4msu
thanks! I appreciate that.
Can you tell me what exactly the strut brace does? I've been trying to find info all over the internet and pretty much what I have found is that they decrease the struts' ability to move in relation to each other.
Is this correct?
If so, does that mean it helps with the wheel hop problem caused by the IRS?
Or does the strut brace go on the front to reduce body roll? I just assumed you meant rear due to the drag strip application. (I'm a newbie - forgive my ignorance)
Old Dec 2, 2005 | 07:21 AM
JerryL's Avatar
JerryL
The strut brace is a steel skeleton that goes around the transmission/differential assembly to add rigidity. Information and a picture can be found at:
http://www.dynotech-eng.com/dte_c5_diff_strut.htm
Your new tires should solve the wheel hop problem.
Old Dec 2, 2005 | 06:54 PM
chad4msu's Avatar
chad4msu
oooooooh ok! cool!
I had seen that thing somewhere while I was looking around for "strut brace". I thought that could possibly be what you were talking about.
Thanks a million for the info!
To Power vs Durability?
