Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Please help me...
Old Jan 12, 2006 | 03:25 AM
BlackC6LS3's Avatar
BlackC6LS3
Default Please help me...
http://forums.corvetteforum.com/show...44&forum_id=48
ready to kill not even someone, but myself
Old Jan 12, 2006 | 06:17 AM
Special K's Avatar
Special K
Dave, you have +V going to GND. It could be a short in the battery itself but I doubt it. I would start there and get the battery checked first. It's possible you have a +V wire at GND but that should blow a fuse.
Have you had the battery cable completely out of the car? If so, where does the NEG side hook up?
This should not be a big deal so just relax.
Old Jan 12, 2006 | 08:05 AM
ralph's Avatar
ralph
Pinched wires between engine and trany? Connection to starter touching ground?
Small amout of spark is normal, but if it's spitt'n at ya......you got a short.
Old Jan 12, 2006 | 11:24 AM
BlackC6LS3's Avatar
BlackC6LS3
Bob - definitly need to relax
Ralph - its spitting so its shorted somewhere
Now to just find where
Old Jan 12, 2006 | 12:03 PM
Special K's Avatar
Special K
You going to reply to my post or just leave me hanging?
Old Jan 12, 2006 | 12:25 PM
BlackC6LS3's Avatar
BlackC6LS3
Bob - the battery is still in the car. I talked to JD on the phone and i'm going to disconnect the battery to take it out of the equation and use a mutlimeter to on the positive battery cable to make it a ground and check for continuity.
Old Jan 12, 2006 | 01:49 PM
Special K's Avatar
Special K
OK, have you had the battry cables completely disconnected? If so, are you sure you have them terminated correctly? Could they be reversed? I mean could you have +V going to GND and GND going to +V?
Old Jan 12, 2006 | 02:59 PM
BlackC6LS3's Avatar
BlackC6LS3
i only pulled the negative cable so that rules that out...
Old Jan 12, 2006 | 03:02 PM
Special K's Avatar
Special K
Dave, no offense but we all make mistakes. Could it possibly be hooked to +V?
Old Jan 12, 2006 | 04:51 PM
BlackC6LS3's Avatar
BlackC6LS3
no offense taken Bob...the +V also has my amp tap on it and it is in the correct place. After i get home from work later i'll play with it more.
Old Jan 12, 2006 | 05:04 PM
Special K's Avatar
Special K
Wish I was there to help you. It should be an easy fix. If you're talking with JD I'm sure you guys can find it. Feel free to call me also.
Old Jan 12, 2006 | 06:33 PM
_twisted_'s Avatar
_twisted_
I almost positive he'll find a B+ pinched in the bell housing or a skinned wire/batt cable in that area.
Old Jan 12, 2006 | 09:08 PM
ralph's Avatar
ralph
A multi-tester might show you continuity to ground on the positive cable even when there's no short. There are things like the radio and computer that draw some current from the battery even when the car is turned off. Trace the wires back.......Like Joe said you must have a pinched or skinned wire somewhere behind the engine. And make sure it's not shorted at the starter. It's possible for the end of the cable to twist and touch the starter or the block......ask me how i know.
Old Jan 12, 2006 | 09:30 PM
_twisted_'s Avatar
_twisted_
been there
To Please help me...
