Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Question about slicks
Old Mar 13, 2006 | 08:54 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Question about slicks
With the new power I am thinking I should maybe go with some true slicks instead of running the ET Streets at the track. My question is on sizing. What is the smallest wheel and biggest slick I can run on the C5? I know the first choice here will be the CCWs but I don't want to spend that much on the wheels, so what else would you suggest in the wheel category for replacing the backs? What offset? Bogarts? Welds? Thanks!
Old Mar 13, 2006 | 09:20 PM
robz's Avatar
robz
Not sure how much power you are making, but another tire to try is the M&H racemaster slicks in 12x16, you will need an 11" rim
Old Mar 13, 2006 | 09:25 PM
02BLKZ06's Avatar
02BLKZ06
someone is sellign truck rims with ET streets on it and they said somehting about the upper ball joint having to be modified... anyone know what exactly to do??
Old Mar 13, 2006 | 09:36 PM
Cajundude's Avatar
Cajundude
Yea, just take a grinder and grind some aluminum away from the top. I have some 16" IROC wheels that I am running ET Streets on. They will scrape a little if you don't grind the tops down.
Old Mar 13, 2006 | 09:38 PM
02BLKZ06's Avatar
02BLKZ06
is there like a little tutorial about it liek to show you exaclt what nees to be done and where to do it??? that would be nice
Old Mar 13, 2006 | 09:44 PM
Cajundude's Avatar
Cajundude
Standby, I'll go take a pic.
Old Mar 13, 2006 | 09:50 PM
Cajundude's Avatar
Cajundude
You can see the wear spots in this pic. I haven't ground them down yet. It doesn't take much and I really don't give a chit about the IROC rims, but since this was brought up, I will go ahead and doing while I have the car up. Just grind off the two little knubs.
Old Mar 13, 2006 | 10:09 PM
Face's Avatar
Face
What do you plan on running up front?
Old Mar 13, 2006 | 10:11 PM
02BLKZ06's Avatar
02BLKZ06
Thanks alot man, appricate it!
Old Mar 13, 2006 | 10:20 PM
Cajundude's Avatar
Cajundude
Don't know yet. Never had power like this before. Figured I'd get used to the car first before putting on skinnies. I'm sure I'll eventually go with skinnies. Is there much of a drivability difference with the skinnies?
Old Mar 13, 2006 | 10:54 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Not know what power like this means, it is not advise to combine radial fronts with bias ply rears. More sway than you want to deal with.
Far as I have seen Bogart and Welds cost more than CCW and neither makes a wheel for the C5 anyway.
Old Mar 14, 2006 | 03:17 AM
killerREDvette's Avatar
killerREDvette
Default and there might be a little more....
with the ccw wheels we have every thing back there is real tight and in addition to the grinding we had to....
-the greese joint(little nipple on top) needed some T.L.C.-a hammer to flatten it a little.
-the inside of the rim was machined(a little)
and ther still was a little bit of rubbing and we just let it rub it self out-most is gone now unless ther is a "FULL" car but with one seat that is hard to do.............now i don't know if any one else has had to do all this, our car is not a daily driver so more steps have probably needed to be taken but didn't want any one to be cought out in the dark.
Old Mar 14, 2006 | 05:43 AM
Cajundude's Avatar
Cajundude
Power will probably be in the 650-750 range for now. Depending on how I like this and a few upgrades later should yield much more, however, I'm staying in this range for now. I guess I'm thinking the CCWs are more than they really are. I'll check into it. Up till now I've just run my KDW2s up front with the ET Streets in the rear. There is some sway but nothing I can't handle. May be a different story when a run 1.5 or 2 secs quicker.
Old Mar 14, 2006 | 07:27 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
That sure is a lot of power. Good luck with it
Old Mar 14, 2006 | 07:30 AM
Cajundude's Avatar
Cajundude
We'll see! I postponed my tune until Monday. I didn't have time over this past weekend to finish up my installs. I also want to give everything a once over to make sure all is good before I go to get it tuned. That is the expected HP range from what I've seen from others.
Old Mar 14, 2006 | 08:58 AM
robz's Avatar
robz
Take a baby sledge to that puppy.
Old Mar 14, 2006 | 09:00 AM
robz's Avatar
robz
So the rubber doesn't hit the inside of wheel well? No mini tub necessary??
Old Mar 16, 2006 | 12:04 AM
blowntranny's Avatar
blowntranny
1st Gear
what kind of slicks did you get all you reall need is a good soft drag radial
i pilot a zo6
Old Mar 16, 2006 | 09:11 AM
Cajundude's Avatar
Cajundude
The reason I use ET Streets now and am thinking about going to a true slick is for help with driveline shock. You don't get the shock absorption with a drag radial that you do with a slick.
To Question about slicks
