Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
17" Frontrunner tires
Old May 15, 2006 | 06:24 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Default 17" Frontrunner tires
The Mickey Thompson and Goodyear web sites both list 17" frontrunner tires. The Mickey Thompsons have a 2.7" section width and the Goodyears come in a 2.5" or 4" section. Is there a point where a frontrunner tire becomes too narrow to run on a Corvette?
Is anyone running 17" (narrow) front tires? If so, what brand and size?
Thanks,
Charles
Old May 15, 2006 | 09:37 AM
Pit Bull's Avatar
Pit Bull
Charles,
Where did you find the 4" front runner? I looked on Goodyear's website, but couldn't find it. I've been looking for a 17" front as well. The 2.7 tire listed by MT is mainly intended for dragsters and is too narrow. I ran a 3.5 Weld draglite with a 165/15 tire on my mustang, and I thought that was pushing it. One more thing, is the Goodyear tire a bias ply or radial?
Josh
Old May 15, 2006 | 11:31 AM
cbernhardt's Avatar
cbernhardt
The goodyear site does not specify if they are radials or bias. Here is a link: http://www.racegoodyear.com/products/dragspecial.html
The size information is in a PDF file.
Charles
Old May 15, 2006 | 11:57 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Those 17" tires are for dragesters not full size cars.
Most use 15" front tires.
Old May 15, 2006 | 12:08 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
yes Charles you will find those 17's are too skinny for any classes we run.
You can fit a 15 if you buy a Strange Engeering front brake kit and cut off stock mounting ears.
or
One guy put rear brakes on the front and got a 15 to fit
or
one guy shaved half the caliper off to fit a 15
Old May 15, 2006 | 04:48 PM
cbernhardt's Avatar
cbernhardt
I checked with the local Goodyear race tire dealer and their frontrunners are bias ply and are not suitable for a car that weighs as much as the Corvette. The narrowest 17" radial tire I have been able to find is a 205/60. For those of you running 15" rims, what size tire are you using?
Charles
Old May 15, 2006 | 06:31 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
I am afraid I bought my used so I an not sure of the rim size. Maybe 4.5 or 5.4. I am using MT ET Street 15 inch 26" tall, but again, don't forget the new calipers and roters as they will not fit stock
here are some pics before the install
Old May 15, 2006 | 08:23 PM
TLewis4095's Avatar
TLewis4095
I was thinking of trying some rear motorcycle 17" tires...4.5" width, but don't know if they will handle the weight....
Old May 15, 2006 | 08:24 PM
TLewis4095's Avatar
TLewis4095
I'm thinking of narrowing a pair og Zo6 17"s so they would fit.
Old May 15, 2006 | 09:08 PM
cbernhardt's Avatar
cbernhardt
I thought about 17" motorcycle tires also but I'm not sure of the load rating for these tires.
I have a set of 1998 wagonwheels (17" x 8.5") that I was thinking about cutting down to about 4"-5" width.
Charles
Old May 16, 2006 | 04:10 PM
LS1LT1's Avatar
LS1LT1
I wouldn't use motorcycle tires and I never liked the idea of cutting/narrowing/rewelding factory wheels...either go with the CCW skinnies (if you can still get them or find them used) or do what Edgar did and get smaller brakes with some good 15" skinnies/frontrunners.
If on a real budget then just go with a lightweight battery and pull the front sway bar for weight savings off of the nose, pump the hell out of the stock front tires to lower rolling resistance.
To 17" Frontrunner tires
