Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
First time dragging
Old May 21, 2006 | 08:45 PM
C4driver99's Avatar
C4driver99
Default First time dragging
I checked the search menu and didn't find much usefulness. I am going to the strip for the first time this saturday and was wondering how do you keep traction with street tires. The track looks slick and I have seen them spray a fluid to do burnouts on and watched a few funny cars slide. Any tips would be appreciated thanks
Old May 21, 2006 | 08:53 PM
MrNuke's Avatar
MrNuke
I know I will get burned for this, but you should really try to search again, as it has come up plenty of times in the past how to drag race.
Too many variables to give you an answer other than search and read the threads.
Old May 21, 2006 | 09:10 PM
C4driver99's Avatar
C4driver99
i just wanted to know what they spray down to make the track slick so i wont loose control and wreck sorry for being stupid
Old May 21, 2006 | 09:13 PM
STL94LT1's Avatar
STL94LT1
Auto or manual transmission?
Go around the water box. Don't heat the tires, no smokey burnouts. Once around the water, turn the tires over to clean off, then stage.
Most tracks spray down DHT as a track prep.
Old May 21, 2006 | 09:15 PM
MrNuke's Avatar
MrNuke
WTH are you smoking?
Old May 21, 2006 | 09:25 PM
C4driver99's Avatar
C4driver99
auto......Mr nuke i have smoked in the past so **** u
Old May 21, 2006 | 09:43 PM
MrNuke's Avatar
MrNuke
...Which explains your brain's misfiring.. Either way your question STILL makes no sense..
ps. I won't be checking this useless thread anymore as you are either stoned out of your witts or it's a gag-thread..
Old May 21, 2006 | 11:29 PM
FELNGR8's Avatar
FELNGR8
The only thing they spray to do burnouts is water. They used to use bleach but all I ever see now is water from a hose.
That's why you want to drive around the water box with street tires, keep the water off your fronts. Your fronts could pick up enough water to lay in front of your rears at the line, and kill your own launch.
Old May 21, 2006 | 11:34 PM
monkeyvette75's Avatar
monkeyvette75
well for me...
I always drive around the water... dry hop the tires to clean the tread.. roll up to stage.... flush the converter... stall it up just bit .. wait for the last yellow and let her rip... lol
Gosh I miss doing that...
Old May 21, 2006 | 11:53 PM
Nick Goldman's Avatar
Nick Goldman
It's VHT.
-Nick Goldman
Raceway Park Track Announcer
Old May 22, 2006 | 10:37 AM
VAHROOM's Avatar
VAHROOM
Default Actually VHT is part of several products
VHT TrackBite is used in the staging area. There are other VHT products that are used. Go to VHT and it gives more information on the products.
Old May 22, 2006 | 05:42 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
They put water down in the water box for burnouts. They spray VHT down to make the track STICKY.
It looks slipperier then it is.
On street tires, don't go thru the water!
You can do a small burnout on your street tires to get them a bit more sticky for your launch & better your 60' times.
I wouldn't floor it off the line on street tires as you'll probably "sit & spin".
Hope this helps.
Ron
To First time dragging
