Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
help launching A4
Old Jun 17, 2006 | 10:52 PM
jetning's Avatar
jetning
Default help launching A4
c5 with headers, intake and exhaust, Nitto DR. best 60 ft is 2.04, i usually launch at idle, left foot on brake, right on gas pedal. how can i improve my times? thanks.
Old Jun 18, 2006 | 09:06 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I run the Nitto DR's as well...a lot has to do with the track prep...launching from idle is fine but what pressure are you running in the tires?...I usually drop them to 26 lbs. and see if I hook...if not, I keep dropping the pressure 1 lb. at a time till it hooks...I've never had to go below 20 lbs...Nitto says we can go as low as 16lbs. but that's a bit low in my opinion...
Also, be aware that these DR's need a good burn out...I do a solid 5 second burn counting , one, one thousand..two......last weekend I had a poor burnout on my first run and had a 2.08 short time spinning like crazy...I got a good burnout on my second run and cut a 1.91 short time with everything else the same...
Old Jun 18, 2006 | 06:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Arrive with 1/4-1/3 tank of fuel.
Bring idle up as far as possible and yet hold the brakes.
Stage as shallow as possible, i.e. just trip the stage lights.
If you want to substantially reduce short time, install a 2,400rpm TC.
BTW, where are you racing, track, altitude, weather, etc???
Old Jun 18, 2006 | 07:03 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Do you have a hand shift?? if yes, your left foot should be on the clutch That could cause a problem
To help launching A4
