Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
shocks
Old Aug 18, 2006 | 09:15 AM
DSCHULTZ's Avatar
DSCHULTZ
Default shocks
when you change out shocks I want Qa1s which ones do i need for drag racing and do you have to reprogram the computer so it wont be throwing codes.
Old Aug 18, 2006 | 11:41 AM
billiardcue's Avatar
billiardcue
Installed a new set of front QA1 double adjustables yesterday, going to the strip tonight to see the results.
Going to make a pass or two with shocks set at 0 rebound and 8 bump - 24 click settings for each on these shocks. You don't want too much bump so the car will ease back down as you increase speed after the launch.
Also will disconnect the front anti-sway bar for the third and fourth passes to see the results in combination with the shocks.
The drag strip I'm going to has very little hook, I've added 100 lbs ballast and a full tank of gas to acheive a best short time of 1.60 (best 60' time of 1.48 on a good track) going to try a 1/4 tank tonight and if all goes well I will remove ballast.
Old Aug 18, 2006 | 11:48 AM
billiardcue
The computer doesn't know what shocks are on the car if you have standard, Z51 or Z06 suspension, not sure if you disconnect the wiring from F45 suspension.
Old Aug 18, 2006 | 12:11 PM
DSCHULTZ's Avatar
DSCHULTZ
Please Let Me Know Results Thanks In Advance.
Old Aug 23, 2006 | 12:45 PM
billiardcue
The QA1 shocks did allow the front end to raise easier, that result is as I had hoped.
My traction was still poor but I think the clutch pack in the differential is gone, only one wheel spinning during the burnouts. Guess I'll try the new clutch pack from DTE.
Old Aug 23, 2006 | 05:46 PM
DSCHULTZ's Avatar
DSCHULTZ
THANKS FOR INFO its always something when your tring to get car dailed in i reckon thats part of racing.I did go ahead and ordered whole set of qa1s front and rear.
Old Aug 23, 2006 | 06:11 PM
billiardcue
Did you order the double adjustables for the front? I spoke with QA1 and they are working on the doubles for the rear, I will wait for them before I buy rears.
I set the fronts to 5 clicks each bump and rebound when I left the dragstrip and it did make the ride more comfortable in the front. Will be nice to soften the rear up also for cruising.
Old Aug 23, 2006 | 06:53 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
This is shocking!!
Sorry, had to say it...LOL
I have the single adjustables and use 2 up front and rear will vary from 6-9 depending on hook. Don't think it makes much difference...too hard to measure with so many variables
Old Aug 24, 2006 | 07:56 AM
DSCHULTZ's Avatar
DSCHULTZ
I ordered double adj. up front single adj. out back.didnt know they had double adj. rears coming out.
Old Aug 24, 2006 | 02:42 PM
Face's Avatar
Face
I wish I would have went with the doubles up front.. I can't see a need for them for the rear though.
To shocks
