Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Need C4 solid axle pics
Old Oct 11, 2006 | 10:34 PM
TURBO VET's Avatar
TURBO VET
Default Need C4 solid axle pics
I am thinking of putting a solid axle in my C4 and need some pics. Thanks
Old Oct 11, 2006 | 10:57 PM
hookedup's Avatar
hookedup
As soon as I can get the photos off my other computer I'll send you some. In the mean time if Jim 'tpi 421' see's this maybe he can send you his conversion pics & mine .
Good luck,
Dave
Old Oct 11, 2006 | 11:28 PM
pef427's Avatar
pef427
Her are some pics of a 10 bolt on a red vette @ CF CI in BG last May. Maybe the owner will give up some info.
-Patrick
Old Oct 11, 2006 | 11:38 PM
Nitrus rush's Avatar
Nitrus rush
HERE is a whole album from awhile back of a 9" inch, 4 link rear installed in a C4. He started off with a bare housing. Definitely looks like a big project.
Old Oct 11, 2006 | 11:53 PM
TURBO VET's Avatar
TURBO VET
Thanks for the replies. keep them coming.
Old Oct 11, 2006 | 11:59 PM
pef427's Avatar
pef427
Looks like an exciting project to me. I wish there was a pic of where the 4-link bolts to.
Old Oct 12, 2006 | 10:55 AM
tpi 421 vette's Avatar
tpi 421 vette
Give me an Email address, and I can send some pictures. Mine is based off of Hooked Up's, and it's real similar.
Old Oct 12, 2006 | 11:13 AM
tpi 421 vette
http://bowtye8.tzo.com/bowtie8/corve...209Inch_tn.htm
See if this works. These pictures were when I was running 26x11.5x15 ET streets. I have since changed to a 28x12.5x15 ET street.
Old Oct 12, 2006 | 12:13 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
-Patrick
That would be Mr Mackey
Old Oct 12, 2006 | 06:08 PM
TURBO VET's Avatar
TURBO VET
eger62@hotmail.com. Thanks
Old Oct 12, 2006 | 06:11 PM
TURBO VET's Avatar
TURBO VET
Did you have to cut the frame rails to fit the 28x12.5x15 tire? That is the size I would like to run.
Old Oct 12, 2006 | 07:57 PM
tpi 421 vette
Yes they fit with minor wheel well trimming. The frame rails are stock. I sent some more updated pic's.
Old Oct 12, 2006 | 08:05 PM
Bowtie8's Avatar
Bowtie8
Here is what I did. Its a Torque Arm settup.
I run a 28" ET Street, and reused the stock rear rotors and calipers.
Also installed a 4L80e at the same time (took out a ZF)
John
http://bowtye8.tzo.com/bowtie8/corve...0Rear/Bowtie8/
There is progress pics thruout
Old Oct 12, 2006 | 08:20 PM
TURBO VET's Avatar
TURBO VET
John
Is there an advantage to a torque arm set up vs 4 link?
Old Oct 13, 2006 | 08:08 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I wish now I had the NeverLift decals on the axel tubes.
Old Oct 14, 2006 | 01:59 AM
pef427's Avatar
pef427
I knew you would show up. Will the 4-link setup work without cutting my storage boxes on the C3? Can I mount the links to the t/a mounting area?
-Patrick
Old Oct 14, 2006 | 10:17 AM
Bowtie8's Avatar
Bowtie8
Part of the reason I went the torque arm route was exactly this. The back half of the car was going to have to be removed to properly mount the links, and cross member from each frame rail.
The torque arm is similar to that of a camero settup. I put Hime Joints on all the ends and centered. I haven not made any adjustments except stiffing the passenger rear QA1. This got the front end to lift evenly.
I think either settup is going to provide the stregth and traction capability your looking for. The Torque Arm is by far less work-but not as common.
I hope to put my car in the high 8's soon, which will be a testimony of the rear settup on a 28" ET Street.
John
To Need C4 solid axle pics
Old Oct 14, 2006 | 05:43 PM
pef427's Avatar
pef427
John
I would definately like to see pics of this setup. May be what I'm looking for. Thanks!
pflournoy@gt.rr.com
Old Oct 14, 2006 | 07:04 PM
Bowtie8's Avatar
Bowtie8
pflournoy@gt.rr.com
There is a link in a previous posting above. All the pics are there
John
Old Oct 14, 2006 | 10:23 PM
pef427's Avatar
pef427
Sorry, i noticed it right after but life took over and couldn't correct in time. Was this a kit or something you designed and pieced together?
-P
