Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Offset question
Old Oct 15, 2006 | 08:05 PM
YO-EL's Avatar
YO-EL
Default Offset question
I'm running 315/35/17 BFG drag radials on a 17x11 ZR-1 rim 56 mm offset, and am noticing rubbing on the inside part of the wheel well plastic liner..
Is anyone else having this?
The rim clearly shows 56 as the offest..
I was told the higher the offset, the less the tire sticks out, but I didn't know about the rubbing...
Can anyone advise on this?
Thanks..
Old Oct 15, 2006 | 08:21 PM
jpee's Avatar
jpee
Thats the same size rim & tire I use.. with no prob.. however I'm a C4 where did you get those rims.. I was looking for another pair...I think the stock GM wheels are 36 mm and will stick out..
Old Oct 16, 2006 | 12:38 AM
SmokeGray89's Avatar
SmokeGray89
There are 2 different offsets on the 17x11 wheels. The ZR1 has
a 36mm and the Grand Sport is 50mm.
To Offset question
