Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
C5 Ratchet Shifter : Any interest? [Dialup; No way!]
Old 10-31-2006, 08:09 PM
0EG@EnglandGreen
Supporting Tuner
Support Corvetteforum!
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by REDGAR
Ah thank Chris. Sounds like something fun to have.
Next question, our our transmissions designed to be manually shifted like that? I have read where they are not.
I shifted all the time with the stock shifter. I never used "D" or "3".
This is no different
Old 10-31-2006, 08:10 PM
0EG@EnglandGreen
Supporting Tuner
Originally Posted by SR71
nice work, EG. I have the same shifter in my car. since my tranny is up front and I have a driveshaft instead of a torque tube, I was able to mount my shift lower down in the tunnel. I have a rubber mega boot covering it. it looks good, but getting to the reverse lockout lever is a pia. as a matter of fact the rl lever tore a hole in my rubber boot. if I had it to do over again, I would use a B&M quicksilver shifter. it has no seperate reverse lockout lever. you just pull up on the main lever and shift to park. again, nice work.
Love the TH400. Had one on my 468 big block (not a Vette)
Decided against the Quicksilver or Megashifter because I did not want the long stick movement, plus the shaft is quite tall (for a C5).
Old 11-01-2006, 07:38 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
Originally Posted by EnglandGreen
Are you thinking of hacking up your white FRC, Steve?
no, I have the 'advanced driver' edition w/ the extra pedal
Old 11-01-2006, 10:01 AM
chaase
chaase's Avatar
St. Jude Donor '12
Edgar it shouldn't be a problem, you can manually shift them now the shifter is not set up for an easy precise shift. Optimally you would have a shift kit (or reprogrammed shifts) to truely enjoy a ratchet shifter.
This is an old school mod before there were electronic transmissions that could be programmed to shift exactly how the driver wants. I am not sure I would actually use it while racing (the computer will still shift faster and more consistently), but they are a lot of fun on the street.
Chris
Old 11-01-2006, 10:05 AM
chaase
chaase's Avatar
St. Jude Donor '12
Do you know if this shifter be had with the big chrome T-Handle, those look sooooo cool.
Chris
Old 11-01-2006, 10:30 AM
0EG@EnglandGreen
Supporting Tuner
One pedal too many
Old 11-01-2006, 11:03 AM
0EG@EnglandGreen
Supporting Tuner
Chris
Chris,
Yes, you can get it with the B&M chrome T handle or with a custom handle like mine
Old 02-01-2021, 12:33 PM
Fordracer9
Fordracer9's Avatar
I know this is a 15 year old thread, but somebody PLEASE tell me that the pics are archived someplace. I'll be undertaking a similar project in the next few weeks and can kinda visualize what's going on, but actually seeing it would be MUCH better.
Old 05-03-2021, 04:02 AM
808_c5
808_c5's Avatar
I agree, looking for some visual guidance on what was done.
Old 04-06-2022, 09:38 PM
purplemamba
1st Gear
purplemamba's Avatar
Purplemamba here. I'd love to see your installation of the ratchet shifter into a c5 corvette. I have a b&m 81120, and I'm looking at all kinds of problems before I even get started. Help please!
Old 05-02-2022, 06:53 PM
DRIVER456
DRIVER456's Avatar
Location: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I've done it,Had to heavily modify shifter and I used the stock shifter cable.
Old 06-10-2022, 03:44 PM
Autotragic
Autotragic's Avatar
I love when someone will say "I modified such and such" or I had to make a custom widget" or whatever and don't even show a picture what they did.
Like okay, what I am I supposed to do with that information?
https://www.corvetteforum.com/forums...et-shifer.html
This OP of this thread shows exactly what I want but says he made "custom brackets". Wish he showed what he did so I could do it.
Old 06-11-2022, 08:11 AM
  #33
DRIVER456
DRIVER456's Avatar
St. Jude Donor '07
When I have some time I'll post pics of how I did it
Autotragic (06-11-2022)
Quick Reply: C5 Ratchet Shifter : Any interest? [Dialup; No way!]
