Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
drag only setup
Old Nov 11, 2006 | 03:58 AM
minytrker's Avatar
minytrker
Default drag only setup
Im building a c5 coupe for drag racing only pretty much. I am converting it to auto and plan on leaving the irs till it breaks. Whats the best suspension setup. Here is what I was thinking.
no front sway bar
qa1's in the front
stock height suspension
Old Nov 11, 2006 | 07:27 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
You probably want to do QA1 rear too
How much power you planning to put to it?
Old Nov 11, 2006 | 08:39 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Does QA1 make a true drag shock? If not, look for a drag race shock that has the adjustable settings.
The other QA1 shocks I've seen are not true darg shocks. Typically they come in adjustments of 50/50,70/30 and 90/10
he other adjustables are either hard or soft, both on rebound and compression.
Old Nov 11, 2006 | 10:19 AM
Paul_Z06's Avatar
Paul_Z06
QA1 have a number of settings (I want to say 6) via a **** on the shocks. Now they make them double adjustable.
The original question is very vague. If you plan to put 1000 rwhp through irs, you may have issues. What kind of car are you building? Turbo? Supercharged? Nitrous? NA? If you go with nitrous or supercharger, you'll see a lot more stress and the irs probably won't live very long. I think turbos are a little more forgiving than leaving on 400 shot of spray so the irs may last longer.
Give some details.
Old Nov 11, 2006 | 03:00 PM
minytrker's Avatar
minytrker
Give some details.
Its going to be a nitrous car ( c5 coupe) but may end up bracket racing it on all motor somwtimes.The car is going to be grudge raced more than anything. We not looking for anything super fast but 5's in the 1/8 is what I want. The car will also have to be able to be driven on the street sometimes. The goal is to be light as possible but yet look fairly stock if you look in the windows. Everything from under the hood that wasnt needed is gone. Looking for two racing seats now.
Old Nov 11, 2006 | 06:24 PM
C3AV's Avatar
C3AV
you only want to go 5's in the1/8..not so fast, if you buy my car, you can still keep yours and save 35,000.not to mention years of testing, are you ready to start the endless journey?
Old Nov 11, 2006 | 09:37 PM
Face's Avatar
Face
QA1's have 12 settings.
Old Nov 11, 2006 | 10:02 PM
minytrker's Avatar
minytrker
I would be happy running 5.99's. I know we can go in the 6's pretty easy. I would like 5's but Im not gonna break the bank trying if it goes low 6's all the time without going through a lot of parts.
Old Nov 11, 2006 | 10:41 PM
C3AV's Avatar
C3AV
cool..goodluck,start w/ the biggest engine you can afford..its a short cut
Old Nov 13, 2006 | 03:34 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Start with the CCW drag pack and another 45K and you are their.
Old Nov 13, 2006 | 11:18 AM
minytrker's Avatar
minytrker
I wont even be close to 45k for low 6's unless something goes wrong. Can't say about 5's. I have camaro's running mid 6's and have less than 10k total in them counting the cars. I know a vette is more money but everything else is the same except for the IRS pretty much. Well I guess it all depends on how you build the cars and who does the work on how much you could have in them. I have my own business and do all the work so that saves alot vs someone dropping a car off and writing a check.
Old Nov 13, 2006 | 07:01 PM
mean lx's Avatar
mean lx
I had very little in my mustang and ran sixes on the motor. I plan on running low sixes in my vette with a 422" LS7 headed motor and a stick. James
Old Nov 13, 2006 | 08:24 PM
HawkIVette's Avatar
HawkIVette
I have QA1's on my '99 FRC and they are double adjustable (on compression and rebound). I have found a 2 setting in the front and a 11 setting in the rear works good for me. At 425 Hp, I can just barely get the tires off the ground with a stock susupension height.
Old Nov 13, 2006 | 09:00 PM
mean lx's Avatar
mean lx
Very nice launch! Not much wasted energy. James
Old Nov 22, 2006 | 01:45 AM
minytrker's Avatar
minytrker
Wow that is impressive. Are you still running a 6 speed?
Old Nov 22, 2006 | 07:55 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Hey Lorenz I see you list SC as one of your locations. Is that where the ar is? You may want to consider running in our National Corvette Challenge in Richmond Virginia in Feb next year.
Old Nov 22, 2006 | 02:28 PM
minytrker's Avatar
minytrker
Yeah the car is in SC for right now. Richmond Virginina is a little to far to go for me. We have two z06's we are trying to run, so taking two vettes, truck and trailer and all the other stuff that far to much of a pain. I would love to go but Im pretty sure I cant make that in Feb.
To drag only setup
