Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
From posi to spool?
Old Dec 28, 2006 | 10:10 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default From posi to spool?
I'm thinking about switching from my 12-bolt posi (IRS) to a spool and I wonder if that would give me a noticeable improvement in my ET's as the spool is about 20 lbs lighter than a posi???
Has anybody done that (without any other changes) and what were the results?
I'm mostly interested in it from a performance and not strength perspective as the posi unit in my diff is very strong...
Old Dec 28, 2006 | 04:19 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
it should pick you up a couple of numbers in 60' and maybe a lil mph
Old Dec 28, 2006 | 06:52 PM
GrandSportC3
If it would be worth a tenth at the track, it would be worth the change...
Old Dec 28, 2006 | 07:09 PM
Major Spray's Avatar
Major Spray
It should be worth the tenth you are looking for
Old Dec 28, 2006 | 07:16 PM
GrandSportC3
That would be sweet.. Maybe I'll get the spool before the national Corvettechallenge..
My best is 10.35 in 62 degree weather.. If I'll get another tenth off with the spool, I'd be at 10.25.. If I'd be able to race in 45 degree weather, I might get into the 10.0x range on engine... That would be sweeeeeeet!! A 100 shot could get me deep into the 9's then..
Old Dec 28, 2006 | 09:55 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Go for the lightened versions..you can get some real featherweight ones.
JIM
Old Dec 28, 2006 | 10:07 PM
GrandSportC3
JIM
I have to go with whatever Tom's offers as those spools are modified by toms to fit their 12-bolt IRS setups..
Old Dec 28, 2006 | 10:30 PM
redvetracr's Avatar
redvetracr
I have a spool made for a Corvette diff by Strange Engineering many years ago, it has been sitting in a box for the last 20 years or so, solid shaft w/bolt on side yokes.....neat piece if anyone is interested...
...redvetracr
Old Dec 28, 2006 | 10:44 PM
vetteman9368
St. Jude Donor '08
I'm one hundred percent sure its not a 31 spline 8.8 FORD spool thats been machined on one end to fit in that case (I forget which end and how much)
Old Dec 29, 2006 | 01:26 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Jeb makes spools on the form here and here are some others
http://nationaldrivetrain.com/shopsi...tml/spool.html
http://www.precisiongear.com/dana44v.htm
The spool will make the car hande different than it does now.
When you turn, it will nose dive on you and make those turns wide.When you make turns the steering wheel will want to kick back .
If you get crossed up just let out of the gas and the car will come back around.Make sure you stage streight.
For a drag car it is the only way to go.
www.dragvette.com is another good site and they will give you alot of info.
http://72.14.253.104/search?q=cache:...s&ct=clnk&cd=2
Old Dec 29, 2006 | 11:06 AM
GrandSportC3
I highly doubt that they'd fit my setup...
Old Jan 1, 2007 | 11:19 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Like Jim said, If you are going to do it get a lightened one. A car with a spool drives a little different, but not that noticeable, until you try to push it around a corner
Good luck on the 9's.......it will happened this year for sure.
Old Jan 1, 2007 | 12:13 PM
GrandSportC3
As I said before, I can only go with the spool that Tom's Differentials offers as no other spools will fit my setup.. Those are specifically machined to fit my differential case..
Old Jan 1, 2007 | 12:24 PM
69 N.O.X. RATT
I understand the 12 bolt IRS deal as far as fit goes.....but does Tom only offer one spool??
I had a really nice spool IRS set up a few years back...I think I sold it to red79454.
Old Jan 1, 2007 | 12:37 PM
GrandSportC3
My understanding is that there's only one type of spool available...
Old Jan 1, 2007 | 02:13 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
Looks like nice setup of ring and pinion!
Old Jan 2, 2007 | 09:56 AM
vetteman9368
St. Jude Donor '08
Oliver, the Tom's spool is an 8.8 ford, 31 spline piece, with one end (driver's side i beleive) machined .200 shorter. If you know of a good machine sho and you take him the new spool and your current posi setup they should be able to modify it with no problems
To From posi to spool?
Old Jan 2, 2007 | 11:43 AM
GrandSportC3
hmmm.. I'd need to know for sure if it's the drivers side... I wonder how much a machine shop would charge to modify the spool and install it???
Tom's wants $600 and I'll get my posi back. Strange makes a lightweight chromoly spool ($188.69 at Summit)
If it would be less than $400 at the machine shop, it'll be cheaper that way...
Old Jan 2, 2007 | 02:33 PM
vetteman9368
St. Jude Donor '08
if I had a 8.8 spool i could tell you, as i have 4 Tom's pieces. I'd just need to measure
Old Jan 2, 2007 | 03:44 PM
GrandSportC3
You have 4? Why do you ned that many?
Wanna sell one?
