Hi, I was having a discussion with a friend from work about this. My argument was that normally the car with the higher trap speed will make more power and be faster from a roll. He disagrees, saying that a good short time will lower your trap speed by 4 or 5 mph and therefore make the trap speed meaningless. If that's true, then why do I have 4 time slips, same car, same day, and same track. The only difference being the short time varies as much as .5 sec. Yet the trap speeds never vary more than 1mph. These were 1/8 mile runs.
I don't race 1/8th mile, but the launch is much more important in the 1/8th mile and I don't think you get the true effect of the HP in such a short distance.
MPH reflects the available HP that you have on that run:
ET is a function of how-well you APPLY that power to the track via gearing, traction, chassis, driving-technique, etc.
You can get the same-car (with no changes between rounds ) to get 60'-times that vary better than a tenth of a second in back-to-back runs, yet record nearly identical MPH figures (adjusted only for atmospheric changes ), simply by staging the car differently.
I don't believe 1/8-mile or 1/4-mile data should have any-bearing on your findings.
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
A lower 60' time can lower your mph at the traps, but so can many other things such as shift speed & shift points.
Also, tire spin on the shifts (or launch) can inflate mph....
